Hello, All!
If you have any advice, please tell me.
I want to build aps-at to ESP32-DevKitC using ESP-IDF.
esp-at:
https://github.com/espressif/esp-at
Referenced method :
https://github.com/espressif/esp-at/blo ... 2-platform
When I perform ">build.py flash" in step 4, I get the following error:
Part of PATH is replaced with "xxxxx".
cmd.exe /C "cd /D xxxxx\esp-idf\co...6/Desktop/esp-idf/components/esptool_py/run_esptool.cmake"
usage: esptool write_flash [-h] [--erase-all]
[--flash_freq {keep,40m,26m,20m,80m}]
[--flash_mode {keep,qio,qout,dio,dout}]
[--flash_size FLASH_SIZE]
[--spi-connection SPI_CONNECTION] [--no-progress]
[--verify] [--encrypt]
[--ignore-flash-encryption-efuse-setting]
[--compress | --no-compress]
<address> <filename> [<address> <filename> ...]
esptool write_flash: error: argument <address> <filename>: [Errno 2] No such file or directory: 'customized_partitions/server_cert.bin'
esptool.py --chip esp32 -p COM14 -b 460800 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 40m --flash_size 4MB 0x8000 partition_table/partition-table.bin 0x10000 ota_data_initial.bin 0xf000 phy_init_data.bin 0x1000 bootloader/bootloader.bin 0x100000 esp-at.bin 0x20000 at_customize.bin 0x24000 customized_partitions/server_cert.bin 0x26000 customized_partitions/server_key.bin 0x28000 customized_partitions/server_ca.bin 0x2a000 customized_partitions/client_cert.bin 0x2c000 customized_partitions/client_key.bin 0x2e000 customized_partitions/client_ca.bin 0x37000 customized_partitions/mqtt_cert.bin 0x39000 customized_partitions/mqtt_key.bin 0x3B000 customized_partitions/mqtt_ca.bin 0x30000 customized_partitions/factory_param.bin
CMake Error at run_cmd.cmake:14 (message):
esptool.py failed
run_esptool.cmake:21 (include)
FAILED: CMakeFiles/flash
cmd.exe /C "cd /D xxxxx\esp-idf\components\esptool_py && xxxxx\.espressif\tools\cmake\3.16.4\bin\cmake.exe -D IDF_PATH="xxxxx/esp-idf" -D ESPTOOLPY="xxxxx\.espressif\python_env\idf4.2_py3.8_env\Scripts\python.exe xxxxx/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32" -D ESPTOOL_ARGS="--before=default_reset --after=hard_reset write_flash @flash_args" -D WORKING_DIRECTORY="xxxxx/esp-idf/esp-at/build" -P xxxxx/Desktop/esp-idf/components/esptool_py/run_esptool.cmake"
ninja failed with exit code 1
idf.py build ret: 2
idf.py build failed
Now, I don't use it, so I have disabled the Bluetooth function.
Please let me know if you have any advice.
Sorry for the poor English.
Thank you.
About esp- at build by ESP-IDF
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], PerplexityBot and 1 guest
- All times are UTC
- Top
- Delete cookies
About Us
Information
