JTAG on LyraT-Mini v1.2
l.wuyts
Postby l.wuyts » Thu Mar 25, 2021 7:44 am
Hello everyone,
I'm trying to use the JTAG interface of the LyraT-Mini developement board, but I can't seem to get it working.
I saw in the schematic that some pins of the JTAG are shared with the SD card interface, does this conflict when using JTAG?
Do I need to remove the 0 ohm resistors to the SD card interface to be able to flash the ESP32 over JTAG?
I'm using a J-Link Ultra+ with the winUSB driver and openocd.
This is my openocd output:
> Executing task in folder IPROG-80LANBOARD-T1-APP: openocd -f interface/jlink.cfg -f esp32-openocd.cfg <
Open On-Chip Debugger  v0.10.0-esp32-20200709 (2020-07-09-08:54)
Licensed under GNU GPL v2
For bug reports, read
Warn : Transport "jtag" was already selected
Info : Configured 2 cores
Info : J-Link Ultra V5 compiled Aug 24 2020 10:18:43
Info : Hardware version: 5.00
Info : VTarget = 3.269 V
Info : clock speed 10000 kHz
Error: No symbols for FreeRTOS
Error: Target not examined yet
Error executing event gdb-attach on target esp32:
Error: Target not halted
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
If anyone has any clues please let me know. :)
Kind regards
Laurens
Users browsing this forum: Amazon [Bot], Baidu [Spider] and 1 guest
