ESP32 SPI driver 4.2inc waveshare e-paper but can't refresh
Posted: Tue Mar 30, 2021 12:32 pm
by liankafohali
I have designed a 4.2-inch E-paper(ink screen) driver board, and the control is ESP-WROOM-32. There is no problem in blink example by IDF-included. When I modify the driver from the official of the screen , it is unable to refresh . Because this is the first time I use ESP32, I suspect that my SPI setting has a problem. Can someone help me :?:
The e-paper driver
[/img]
ESP32
Code: Untitled.c Select all
/* Blink Example
This example code is in the Public Domain (or CC0 licensed, at your option.)
Unless required by applicable law or agreed to in writing, this
software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied.
#include <stdio.h>
#include "driver/gpio.h"
#include "sdkconfig.h"
#include "driver/spi_common.h"
#include "driver/spi_master.h"
#include "freertos/task.h"
#include "EPD_Test.h"
#include "EPD_4in2.h"
/* Can use project configuration menu (idf.py menuconfig) to choose the GPIO to blink,
or you can edit the following line and set a number here.
#define BLINK_GPIO 16//0 is turn on,1 is turn off
//the list pins are controled by spi
//#define PIN_NUM_MISO 37
#define PIN_NUM_MOSI 13
#define PIN_NUM_CLK 14
#define PIN_NUM_CS 15
#define PIN_NUM_RST 2
#define PIN_NUM_BUSY 4
#define PIN_NUM_DC 12
esp_err_t ret;
spi_device_handle_t spi;
spi_transaction_t t;
void gpio_init(void){
/* Configure the IOMUX register for pad BLINK_GPIO (some pads are
muxed to GPIO on reset already, but some default to other
functions and need to be switched to GPIO. Consult the
Technical Reference for a list of pads and their default
functions.)
gpio_pad_select_gpio(BLINK_GPIO);
/* Set the GPIO as a push/pull output */
gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
/*e-paper rest pin ,mode is output*/
gpio_pad_select_gpio(PIN_NUM_RST);
gpio_set_direction(PIN_NUM_RST, GPIO_MODE_OUTPUT);
/*e-paper data or command pin ,mode is output*/
gpio_pad_select_gpio(PIN_NUM_DC);
gpio_set_direction(PIN_NUM_DC, GPIO_MODE_OUTPUT);
/*e-paper busy pin ,mode is input*/
gpio_pad_select_gpio(PIN_NUM_BUSY);
gpio_set_direction(PIN_NUM_BUSY, GPIO_MODE_INPUT);
void spi_init(void){
spi_bus_config_t my_config={
.miso_io_num=-1,
.mosi_io_num=PIN_NUM_MOSI,
.sclk_io_num=PIN_NUM_CLK,
.quadwp_io_num=-1,
.quadhd_io_num=-1,
.max_transfer_sz=1000,
spi_device_interface_config_t my_device={
.flags=SPI_DEVICE_NO_DUMMY,
.input_delay_ns=10,
.command_bits=0,
.address_bits=0,
.clock_speed_hz=10*1000*1000,
.mode=0,
.spics_io_num=-1,
.queue_size=7,
ret=spi_bus_initialize(HSPI_HOST, &my_config, 0);
ESP_ERROR_CHECK(ret);
ret=spi_bus_add_device(HSPI_HOST, &my_device, &spi);
void app_main(void)
gpio_init();
spi_init();
printf("SPI gpio Init success!");
//DEV_Module_Init();
//EPD_4IN2_Init();
printf("EPD Init success!");
//EPD_4IN2_Clear();
EPD_4in2_test();
while(1) {
/* Blink off (output low) */
printf("Turning off the LED\n");
gpio_set_level(BLINK_GPIO, 0);
/* Blink on (output high) */
printf("Turning on the LED\n");
gpio_set_level(BLINK_GPIO, 1);
vTaskDelay(9000 / portTICK_PERIOD_MS);
spi devconfig.c
#include "DEV_Config.h"
#include <string.h>
extern esp_err_t ret;
extern spi_device_handle_t spi;
extern spi_transaction_t t;
//SPI_TRANS_USE_RXDATA
void DEV_SPI_WriteByte(UBYTE value)
//memset(&t,0,sizeof(t));
t.flags=SPI_TRANS_USE_TXDATA;
t.length=8;
t.tx_data[0]=value;
t.rx_buffer=NULL;
//HAL_SPI_Transmit(&hspi1, &value, 1, 1000);
//spi_device_transmit(spi,&t);
spi_device_polling_transmit(spi,&t);
assert(ret==ESP_OK); //Should have had no issues.
void DEV_Module_Init(void)
DEV_Digital_Write(EPD_DC_PIN, 0);
DEV_Digital_Write(EPD_CS_PIN, 0);
DEV_Digital_Write(EPD_RST_PIN, 1);
void DEV_Module_Exit(void)
//close 5V
DEV_Digital_Write(EPD_RST_PIN, 0);
devconfig.h
#ifndef _DEV_CONFIG_H_
#define _DEV_CONFIG_H_
#pragma once
#include <stdint.h>
* data
#define UBYTE uint8_t
#define UWORD uint16_t
#define UDOUBLE uint32_t
* e-Paper GPIO
#define EPD_RST_PIN 2
#define EPD_DC_PIN 12
#define EPD_CS_PIN 15
#define EPD_BUSY_PIN 4
* GPIO read and write
#define DEV_Digital_Write(_pin, _value) gpio_set_level(_pin, _value == 0? 0:1)
#define DEV_Digital_Read(_pin) gpio_get_level(_pin)
* delay x ms
//#define DEV_Delay_ms(__xms) vTaskDelay(__xms/ portTICK_RATE_MS)
void DEV_SPI_WriteByte(UBYTE value);
void DEV_Module_Init(void);
void DEV_Module_Exit(void);
#endif
The monitor output
Re: ESP32 SPI driver 4.2inc waveshare e-paper but can't refresh
Posted: Wed Mar 31, 2021 3:38 am
by Sprite
Not sure if it matters, but in your GPIO initialization, you seem to have forgotten to also initialize CS as an output.
Posted: Wed Mar 31, 2021 8:07 am
by liankafohali
thank you for you reply,this is my carelessness,my problem has been solved。 :D
