rainmaker cli fail
colinives
rainmaker cli fail
Postby colinives » Wed Mar 31, 2021 2:29 pm
Hi there,
I've come back to the rainmaker part of my project and the CLI is now failing to run. I've reinstalled rainmaker and rerun the clip setup requirements.txt but I get this when trying to login (or any other cli command. Any ideas>?
I ran: ./rainmaker.py login <my email address>
Failed to import ESP Rainmaker library. dlopen(/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/cryptography/hazmat/bindings/_constant_time.abi3.so, 2): no suitable image found.  Did find:
	/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/cryptography/hazmat/bindings/_constant_time.abi3.so: no matching architecture in universal wrapper
  File "/Users/colinives/esp/esp-idf/esp-rainmaker/cli/./rainmaker.py", line 19, in <module>
    from rmaker_cmd.node import *
  File "/Users/colinives/esp/esp-idf/esp-rainmaker/cli/rmaker_cmd/node.py", line 34, in <module>
    raise err
  File "/Users/colinives/esp/esp-idf/esp-rainmaker/cli/rmaker_cmd/node.py", line 31, in <module>
    from rmaker_tools.rmaker_claim.claim import claim
  File "/Users/colinives/esp/esp-idf/esp-rainmaker/cli/rmaker_tools/rmaker_claim/claim.py", line 28, in <module>
    from cryptography import x509
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/cryptography/x509/__init__.py", line 8, in <module>
    from cryptography.x509.base import (
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/cryptography/x509/base.py", line 16, in <module>
    from cryptography.x509.extensions import Extension, ExtensionType
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/cryptography/x509/extensions.py", line 18, in <module>
    from cryptography.hazmat.primitives import constant_time, serialization
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/cryptography/hazmat/primitives/constant_time.py", line 11, in <module>
    from cryptography.hazmat.bindings._constant_time import lib
ImportError: dlopen(/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/cryptography/hazmat/bindings/_constant_time.abi3.so, 2): no suitable image found.  Did find:
Any tips on where I even start to solve this?
Thank you
colinives
Re: rainmaker cli fail
Postby colinives » Wed Mar 31, 2021 6:50 pm
What may have caused the problem is that I installed a virtual environment for doing some python GUI work. I've uninstalled the environment (pip uninstall virtualenv) and reinstalled python with the latest release. All fixed
