Does ESP32-S2 support i2s built-in ADC?
Hi I have bought ESP32-S2 board and tried its i2s built-in ADC. But it did not work. The error showed "I2S_MODE_ADC_BUILT_IN' was not declared in this scope". So if someone knows that whether ESP32-S2 support i2s built-in ADC? Thanks a lot!
Re: Does ESP32-S2 support i2s built-in ADC?
On the -S2, the ADC doesn't use I2S for DMA anymore, it can do DMA by itself. Unfortunately, we don't really have a nice example to show that off, but you may be able to get some hints from the driver test code in esp-idf at components/driver/test/adc_dma_test .
Thank you for the reply! So that means it can achieve high ADC sampling rate (e.g. 100kHz) without i2s, right?
And, will you provide the relevant example in the near future?On the -S2, the ADC doesn't use I2S for DMA anymore, it can do DMA by itself. Unfortunately, we don't really have a nice example to show that off, but you may be able to get some hints from the driver test code in esp-idf at components/driver/test/adc_dma_test .
Users browsing this forum: Applebot, Baidu [Spider], meta-externalagent and 1 guest
