Send and receive custom packet
Alterane
Postby Alterane » Thu Jun 01, 2017 7:23 pm
I want to build a real secure mesh network without the use of standard protocol or limitation.
I have seen this http://blog.podkalicki.com/esp32-wifi-sniffer/ to receive all packet with the promiscuous mode, i just need to find somthing to send custom packet, now because this work find :).
I have seen this https://github.com/Jeija/esp32free80211 but that was not compatible now, and i didn't find the way to make this work :/
Can some one have a way to send custom packet, and it's better if i can still use promiscuous mode to receive them all :) ?
igrr
Re: Send and receive custom packet
Postby igrr » Fri Jun 02, 2017 1:07 am
There is an official API for sending 802.11 frames coming to the SDK in a few days. It has the same limitations as on the 8266 (no management frames) but that should be okay for your use case.
HardwireIO
Postby HardwireIO » Tue Aug 15, 2017 6:14 am
Hi Alterane!
Did you managed to send and receive custom packets?
We're trying to do the same but with last Esp-IDF in promiscuous mode we don't receive DATA packets even though we set filtering.
It looks like filtering function is broken.
Hardwire.io / The IoT Platform
mrdebug
Postby mrdebug » Tue Apr 07, 2020 12:39 pm
Hi, have you found the way to send custom packets?
Users browsing this forum: Bytespider, Google [Bot] and 1 guest
