SPI Master Read only still sets data on MOSI line
rfleming
Postby rfleming » Thu Apr 08, 2021 1:52 am
Hi All,
When using SPI, some instances I only need to do a read and parse through dummy data. While right now the external ICs I am working with disregard the dummy data that is transmitted, this could be an issue in the future, so I am trying to nut it out now. In the below read example, for some reason, when the read occurs, the TX sends through more than just 0xFF, or 0x00s. In a few different transactions it would send the same {0xDD, 0x35, 0x45, 0xFE} dummy characters through my various transactions. Is it possible to force this to be 0xFFs or even 0x00s?
void ReadData(spi_device_handle_t handle, uint8_t* read_buf, uint32_t read_len) {
	spi_transaction_t t;
	memset(&t, 0, sizeof(t));  //Zero out the transaction
	/* required since read_buf is unlikely aligned to 32bit carrier */
	uint8_t* tmp_read = (uint8_t*)malloc(read_len);
	if (tmp_read == NULL) {
		puts("SPI: Couldn't malloc");
		return false;
	t.length = 8 * read_len;  //length is in bits.
	t.tx_buffer = NULL;		  // Pointer to transmit buffer, or NULL for no MOSI phase
	t.rx_buffer = tmp_read;
	t.rxlength = 0;							//0 forces it to be the same as 'length'
	t.user = (void*)0;						//context or random pointer. Perhaps use for callback function if used for async?
	esp_err_t ret = spi_device_transmit(handle, &t);	//blocking
	memcpy(read_buf, tmp_read, read_len);
	free(tmp_read);
	return ret;
chegewara
Re: SPI Master Read only still sets data on MOSI line
Postby chegewara » Thu Apr 08, 2021 11:39 am
Did you try:
        t.length = 0;
	t.rxlength = 8 * read_len;  //length is in bits.
rfleming
Postby rfleming » Fri Apr 09, 2021 2:50 am
No i haven't. Reading documentation for those fields though, looking at spi_master.h
size_t length;                  ///< Total data length, in bits
    size_t rxlength;                ///< Total data length received, should be not greater than ``length`` in full-duplex mode (0 defaults this to the value of ``length``).
Just based on the comment, I didn't want to touch it at all :cry:
hmbacher
Postby hmbacher » Thu Dec 26, 2024 9:32 pm
this topic is a few years old, but it seems not been answered finally. I am facing the same issue: I do a burst read of a CC1101 chip and after sending the address byte, I expect MOSI to stay low (0x00) during all subsequent bytes in Read / MISO phase.
My code:
spi_transaction_ext_t t;
t.base.flags = SPI_TRANS_VARIABLE_ADDR;
t.base.addr = regAddr | READ_BURST;
t.base.length = 8 * len;
t.base.rx_buffer = buffer;
t.address_bits = 8;
spi_device_polling_transmit(_handle, (spi_transaction_t *)&t);
Has anyone implemented a "real" MOSI phase skipping yet? Thank you very much!
Users browsing this forum: Applebot, ChatGPT-User, PetalBot and 3 guests
