memory leak using cJson ESP32
Pedrojdi
Postby Pedrojdi » Tue Apr 13, 2021 9:22 pm
Please could someone help me to identify why there is a memory leak using cJson I could not find the problem. whenever I do an authentication the live memory decreases. The json is created only at that point, I have already changed the control logic but in any case it always ends up leaking memory
esp_err_t loginWS(httpd_req_t *request) {
    JwtService jwtService;
    AutenticationModel autenticationModel;
    AutenticationService autenticationService;
    autenticationModel = autenticationService.loadRegister();
    cJSON *jsonWs;
    cJSON *params;
    std::string token = "";
    std::string msg = "";
    std::string body = "";
    std::string login = "";
    std::string password = "";
    bool error;
    body = _getBody(request); //json received
    jsonWs = cJSON_Parse(body.c_str());
    login = cJSON_GetObjectItem(jsonWs, "_login")->valuestring;
    password = cJSON_GetObjectItem(jsonWs, "_password")->valuestring;
    if (login == autenticacaoModel.getLogin() && senha == autenticacaoModel.getPassword()) {
        token = jwtService.criarJwt();
        msg = "";
        error = false;
        token = "";
        msg = "Login or password invalid";
        error = true;
    cJSON_AddItemToObject(jsonWs = cJSON_CreateObject(), "token", params = cJSON_CreateObject());
    cJSON_AddItemToObject(params, "token", cJSON_CreateString(token.c_str()));
    cJSON_AddItemToObject(jsonWs, "message", params = cJSON_CreateObject());
    cJSON_AddItemToObject(params, "error", cJSON_CreateBool(erro));
    cJSON_AddItemToObject(params, "msg", cJSON_CreateString(mensagem.c_str()));
    const char *texto = cJSON_Print(jsonWs);
    cJSON_Delete(jsonWs);
    httpd_resp_set_hdr(request, "Content-Type", "application/json");
    httpd_resp_sendstr(request, texto);
    free((void *)texto);
    return ESP_OK;
WiFive
Re: memory leak using cJson ESP32
Postby WiFive » Tue Apr 13, 2021 9:53 pm
You did not free jsonWs before you reused it
Pedrojdi
Postby Pedrojdi » Tue Apr 13, 2021 10:16 pm
good night colleague, how to release jsonWS using the command free(jsonWs);
In which part of the program I would release, because by placing this command the program restarts
thank you so much
WiFive
Postby WiFive » Tue Apr 13, 2021 11:39 pm
Users browsing this forum: ChatGPT-User, Google [Bot], Qwantbot and 1 guest
