ULP RISC-V temperature sensor configuration
bitmandu
Postby bitmandu » Mon Apr 26, 2021 3:23 pm
I am trying to take periodic temperature measurements from the ULP RISC-V coprocessor on the ESP32-s2.
The following code reads the on-chip temperature sensor from the ULP and is based on section 30.4.3 of the technical reference.
static uint32_t read_temperature(void)
    uint32_t temp, ready;
    SET_PERI_REG_MASK(SENS_SAR_TSENS_CTRL_REG, SENS_TSENS_POWER_UP_FORCE);
    SET_PERI_REG_MASK(SENS_SAR_TSENS_CTRL_REG, SENS_TSENS_POWER_UP);
    /* Wait for a while and then configure the register
     * SENS_TSENS_DUMP_OUT. The output value gradually approaches the
     * actual temperature linearly as the measurement time increases.
    for (volatile int i = 0; i < 0xff; ++i)
    SET_PERI_REG_MASK(SENS_SAR_TSENS_CTRL_REG, SENS_TSENS_DUMP_OUT);
    ready = 0;
    while (!ready) {
	ready = REG_GET_FIELD(SENS_SAR_TSENS_CTRL_REG, SENS_TSENS_READY);
    temp = REG_GET_FIELD(SENS_SAR_TSENS_CTRL_REG, SENS_TSENS_OUT);
    CLEAR_PERI_REG_MASK(SENS_SAR_TSENS_CTRL_REG, SENS_TSENS_DUMP_OUT);
    return temp;
The problem is that I don't know how to configure the temperature sensor on the ULP. The above code works ONCE if I have the following
in my application code.
    temp_sensor_config_t config = {
	.dac_offset = TSENS_DAC_L2, // -10 to 80°C, error < 1°C
	.clk_div = 6};
    temp_sensor_set_config(config);
    temp_sensor_start();
Once the main processor goes into deep sleep, the FIRST call to read_temperature() is fine. I believe this works because the main
processor calls temp_sensor_set_config() before going into deep sleep.
However, subsequent calls to read_temperature() fail — SENS_TSENS_READY is never set. Again, I think these fail, because the temperature sensor is no longer configured when the ULP wakes up at the period set by ulp_set_wakeup_period().
Does anybody know how to configure the temperature sensor on the ULP? I don't see anything in the technical reference on this beyond section 30.4.3.
I looked into $IDF_PATH/components/driver/esp32s2/rtc_tempsensor.c, but if I try to call
	REGI2C_WRITE_MASK(I2C_SAR_ADC, I2C_SARADC_TSENS_DAC, 15);
in my ULP code, I get a linker error
main.c:(.text.startup.main+0x66): undefined reference to `i2c_rtc_write_reg_mask'
Thanks in advance for any help!
clinnemann
Re: ULP RISC-V temperature sensor configuration
Postby clinnemann » Sat Dec 07, 2024 10:33 am
I find this question very interesting because in the technical documentation of the esp32-s3 I don't find any hint on how to set the temperature environment.
So if there is any hint please don't hesitate to post it here.
Best,
Christian
MicroController
Postby MicroController » Sun Dec 08, 2024 4:21 pm
ESP32-S3 Technical Reference Manual v1.5, section 39 "On-Chip Sensors and Analog Signal Processing", subsection 39.4 "Temperature Sensor", paragraph 39.4.3 "Functional Description" on page 1454.
Users browsing this forum: Bytespider, PerplexityBot and 0 guests
