ESP32-D0WD Design Issue.
MANGUKIA
Contact:
Postby MANGUKIA » Fri Apr 30, 2021 9:34 am
Dear,
Please find below the Schematic connection of the ESP32-D0WD SOIC based custom board design.
I use the ESPProg UART flash method to flash code.
I am successfully able to detect chips as well as able to flash a code using Arduino IDE.
But My issue is code does not run except what we write.
I got continue 115200 Serial rate data over the terminal monitor.
Can anyone confirm what is the exact issue?? based on data its continue SW RESET.
Write code for toggle GPIO as well as Dump "DATA" over serial 9600Bps but I can not show the result Yes, Code flash successful but some issue with RESET SW.
You can find connections, as well as serial data over, attach the image.
Users browsing this forum: Applebot, ChatGPT-User, YisouSpider and 2 guests
