Re: ESP IDF in VS code Failing - Something went wrong while trying to build project.
Posted: Sat May 08, 2021 10:18 am
by bignacio
Can you provide additional information of your setup ?
**Environment (please complete the following information):**
- OS Name & Version: [e.g. MacOS X 10.14.5]
- VSCode Version: [e.g. 1.35.1]
- ESP-IDF Version: [e.g. v3.2.2]
- Python Version: [e.g. 2.7.10]
You can use the "ESP-IDF: Doctor command" to generate a report of your configuration that already provide everything below.
Logs
If applicable, please share the log file which can be obtained from
- Windows: `%USERPROFILE%\.vscode\extensions\espressif.esp-idf-extension-VERSION\esp_idf_vsc_ext.log`
- Linux & MacOSX: `$HOME/.vscode/extensions/espressif.esp-idf-extension-VERSION/esp_idf_vsc_ext.log`
