Why C++ code runs slowly?
Posted: Sun May 16, 2021 12:48 am
by nvtby_espf
Hi! Shown below is a code from C++ method, each statement with elapsed time. I feel it should run 10x times faster on ESP32-S2. Given CPU clock as 4.2 ns per tick (240 MHz), simple sum takes ~60 ticks. I think it's unusually high. I searched for Xtensa docs but did not find reference numbers for how much math instructions take.
Compiler makes code under performance option. Memory is SRAM. Arrays were allocated by "new" operator. Measurements were made by system timer and factored to nanoseconds.
Do you have any idea what's wrong? Did you conduct similar tests but got faster results?
    float* x = matrixTest+1;
    float* y = matrixTest+1+10000;
    int i;
    for( i = 0; i < 10000; i++ )
        if(    ! x[i]      ) break; // 130 ns
        if( y[0] == x[i]   ) break; // 129 ns
        if( y[i] == x[i]   ) break; // 133 ns
        if( x[i]+y[i] < 0. ) break; // 370 ns
        if( y[i]-x[i] < 0. ) break; // 445 ns
        if( y[i]*x[i] < 0. ) break; // 409 ns
        if( y[i]/x[i] < 0. ) break; // 1381 ns
    printf("i=%d\n",i);
Measurements were made when only one line was uncommented. A "matrixTest" array is a class member. It has 40000 elements, resides in heap. It was allocated and initialized before the test.
Re: Why C++ code runs slowly?
Posted: Tue May 18, 2021 12:16 am
by Angus
Hi nvbty,
The ESP32-S2 doesn't have a hardware floating point unit, so all floating point calculations have to be emulated in software. Unfortunately, this is pretty slow.
If you can find a way to use integer or fixed-point math (I believe there are some good C++ fixed point arithmetic libraries out there), then it will be noticeably faster.
It will also be faster on ESP32 or the upcoming ESP32-S3 (both have hardware single-precision floating point units), although floating point calculations are always slower than integer ones even with a hardware FPU.
