Noob question
jackbauer
Noob question
Postby jackbauer » Tue May 18, 2021 8:56 am
I'm learning how to use the ESP32, so I loaded an example in the ESP32, but now I can't load another example because the current example won't be deleted. Should I format it first?
What should I do and how?
Re: Noob question
Postby Sprite » Tue May 18, 2021 9:12 am
What SDK (arduino, esp-idf, ...) are you using and how are you 'loading' the example?
jackbauer
Re: Noob question
Postby jackbauer » Tue May 18, 2021 9:17 pm
Hi, most info is in this topic viewtopic.php?f=2&t=20959
Using Arduino IDE.
Re: Noob question
Postby Sprite » Wed May 19, 2021 1:48 am
Then, can you define 'but now I can't load another example because the current example won't be deleted. '? What do you do, what error message do you get, what would you expect to happen instead? Please be exact, at the moment your error description is about as clear as 'I tried a thing with an ESP32 and it didn't work, please help me'.
Users browsing this forum: Bing [Bot], ChatGPT-User, Semrush [Bot] and 4 guests
