I set up a TX i2s interface on my esp32 and can see the master clock and left-right clock fine on my osciloscope.
I also set up a a second i2s RX interface with its own clock.
Now I was wondering about two things:
- Can I re-use the TX clock pins to drive both i2s interfaces ?
- Can I read those clock pins like normal GPIO pins? (This has no specific use, just wondering because I tried and I always read 0)
Share I2S clock&WS between both i2s interfaces
Re: Share I2S clock&WS between both i2s interfaces
I have managed to run a loopback from I2S0 TX to I2S1 RX - so yes you can drive the RX clock from TX output.
Unsure, maybe the state is in a peripheral register somewhere, take a look at the technical reference manual.
Thanks for the tip!
I got it to work.
The i2s driver sets the clock pin to OUTPUT.
changed it to input and output and mapped it to the second interface using the gpio matrix
I got it to work.
Users browsing this forum: Amazon [Bot], Qwantbot and 2 guests
