I try to use esp_wifi_get_tsf_time on esp32s2 to timestamp an periodic event on the connected stations. My problem is that esp_wifi_get_tsf_time takes around 48 micro-seconds to evaluate and the periodic event is faster than that (< 30us)
Is there a way to speed up the reading of the TSF time?
I have tried set up an HW timer to the value of TSF to improve read time. That works but I lose precision and can't compare the timestamp from different stations.
esp_wifi_get_tsf_time takes "long" time to execute ~48us
david@millares.se
Re: esp_wifi_get_tsf_time takes "long" time to execute ~48us
Use the function in esp_mesh.h (https://github.com/espressif/esp-idf/bl ... sh.h#L1515), it's way faster (<1us).
Here's a console log of 25 consecutive TSF timestamp readouts using the mesh-lib function:
And here is the same using the WiFi-lib function:
Note however, that the mesh function will only read the STA MAC's TSF-timer value. So to use this function with an AP, you'd either have to put it in APSTA mode and use the STA's TSF-timer for synchronization or you find a way to start the STA TSF-timer without the STA actually running.
esp_mesh_get_tsf_time()Here's a console log of 25 consecutive TSF timestamp readouts using the mesh-lib function:
␛[0;32mI (8884) SyncTSF: <------------------- TIMESTAMP LOG START ------------------->␛[0m
␛[0;32mI (8884) SyncTSF: TSF Timestamp idx 0: 740327222␛[0m
␛[0;32mI (8884) SyncTSF: TSF Timestamp idx 1: 740327227␛[0m
␛[0;32mI (8884) SyncTSF: TSF Timestamp idx 2: 740327228␛[0m
␛[0;32mI (8894) SyncTSF: TSF Timestamp idx 3: 740327229␛[0m
␛[0;32mI (8894) SyncTSF: TSF Timestamp idx 4: 740327230␛[0m
␛[0;32mI (8904) SyncTSF: TSF Timestamp idx 5: 740327231␛[0m
␛[0;32mI (8904) SyncTSF: TSF Timestamp idx 6: 740327231␛[0m
␛[0;32mI (8914) SyncTSF: TSF Timestamp idx 7: 740327232␛[0m
␛[0;32mI (8914) SyncTSF: TSF Timestamp idx 8: 740327233␛[0m
␛[0;32mI (8924) SyncTSF: TSF Timestamp idx 9: 740327234␛[0m
␛[0;32mI (8934) SyncTSF: TSF Timestamp idx 10: 740327235␛[0m
␛[0;32mI (8934) SyncTSF: TSF Timestamp idx 11: 740327236␛[0m
␛[0;32mI (8944) SyncTSF: TSF Timestamp idx 12: 740327237␛[0m
␛[0;32mI (8944) SyncTSF: TSF Timestamp idx 13: 740327238␛[0m
␛[0;32mI (8954) SyncTSF: TSF Timestamp idx 14: 740327238␛[0m
␛[0;32mI (8954) SyncTSF: TSF Timestamp idx 15: 740327239␛[0m
␛[0;32mI (8964) SyncTSF: TSF Timestamp idx 16: 740327240␛[0m
␛[0;32mI (8964) SyncTSF: TSF Timestamp idx 17: 740327241␛[0m
␛[0;32mI (8974) SyncTSF: TSF Timestamp idx 18: 740327242␛[0m
␛[0;32mI (8974) SyncTSF: TSF Timestamp idx 19: 740327243␛[0m
␛[0;32mI (8984) SyncTSF: TSF Timestamp idx 20: 740327244␛[0m
␛[0;32mI (8984) SyncTSF: TSF Timestamp idx 21: 740327245␛[0m
␛[0;32mI (8994) SyncTSF: TSF Timestamp idx 22: 740327245␛[0m
␛[0;32mI (9004) SyncTSF: TSF Timestamp idx 23: 740327246␛[0m
␛[0;32mI (9004) SyncTSF: TSF Timestamp idx 24: 740327247␛[0m
␛[0;32mI (9014) SyncTSF: <-------------------- TIMESTAMP LOG END -------------------->␛[0m
--- exit ---Code: Select all
␛[0;32mI (8914) SyncTSF: <------------------- TIMESTAMP LOG START ------------------->␛[0m
␛[0;32mI (8914) SyncTSF: TSF Timestamp idx 0: 1143745768␛[0m
␛[0;32mI (8914) SyncTSF: TSF Timestamp idx 1: 1143745870␛[0m
␛[0;32mI (8924) SyncTSF: TSF Timestamp idx 2: 1143745952␛[0m
␛[0;32mI (8924) SyncTSF: TSF Timestamp idx 3: 1143746034␛[0m
␛[0;32mI (8934) SyncTSF: TSF Timestamp idx 4: 1143746116␛[0m
␛[0;32mI (8934) SyncTSF: TSF Timestamp idx 5: 1143746198␛[0m
␛[0;32mI (8944) SyncTSF: TSF Timestamp idx 6: 1143746280␛[0m
␛[0;32mI (8944) SyncTSF: TSF Timestamp idx 7: 1143746362␛[0m
␛[0;32mI (8954) SyncTSF: TSF Timestamp idx 8: 1143746444␛[0m
␛[0;32mI (8954) SyncTSF: TSF Timestamp idx 9: 1143746527␛[0m
␛[0;32mI (8964) SyncTSF: TSF Timestamp idx 10: 1143746609␛[0m
␛[0;32mI (8964) SyncTSF: TSF Timestamp idx 11: 1143746691␛[0m
␛[0;32mI (8974) SyncTSF: TSF Timestamp idx 12: 1143746773␛[0m
␛[0;32mI (8974) SyncTSF: TSF Timestamp idx 13: 1143746855␛[0m
␛[0;32mI (8984) SyncTSF: TSF Timestamp idx 14: 1143746937␛[0m
␛[0;32mI (8994) SyncTSF: TSF Timestamp idx 15: 1143747019␛[0m
␛[0;32mI (8994) SyncTSF: TSF Timestamp idx 16: 1143747101␛[0m
␛[0;32mI (9004) SyncTSF: TSF Timestamp idx 17: 1143747183␛[0m
␛[0;32mI (9004) SyncTSF: TSF Timestamp idx 18: 1143747266␛[0m
␛[0;32mI (9014) SyncTSF: TSF Timestamp idx 19: 1143747348␛[0m
␛[0;32mI (9014) SyncTSF: TSF Timestamp idx 20: 1143747438␛[0m
␛[0;32mI (9024) SyncTSF: TSF Timestamp idx 21: 1143747520␛[0m
␛[0;32mI (9024) SyncTSF: TSF Timestamp idx 22: 1143747602␛[0m
␛[0;32mI (9034) SyncTSF: TSF Timestamp idx 23: 1143747684␛[0m
␛[0;32mI (9034) SyncTSF: TSF Timestamp idx 24: 1143747766␛[0m
␛[0;32mI (9044) SyncTSF: <-------------------- TIMESTAMP LOG END -------------------->␛[0m-
david@millares.se
Thanks esp_timer_get_time() is way faster, around 10us (instead of 48us). I will test if that is fast enough for my application.
I have tested to read it once every second in an GPIO ISR. One interesting thing is if I read it twice the second read is fast <2us
Example code:
Single read
esp-idf: git-sha 73db142403c6e5b763a0e1c07312200e9b622673
Double read
Example code:
static void IRAM_ATTR gpio_isr_handler(void* arg)
start_time = esp_timer_get_time();
tsf_time1 = esp_mesh_get_tsf_time();
tsf_time2 = esp_mesh_get_tsf_time();
end_time = esp_timer_get_time();
esp_rom_printf("%lld %lld (%lld us)\n", tsf_time1, tsf_time2, end_time - start_time);
3577430718 (10 us)
3578430716 (9 us)
3579430717 (9 us)
3580430715 (9 us)
3581430716 (9 us)
Double read
3572430714 3572430716 (7 us)
3573430716 3573430718 (9 us)
3574430716 3574430718 (10 us)
3575430716 3575430718 (9 us)
3576430716 3576430718 (9 us)
Last edited by david@millares.se on Tue Jun 15, 2021 10:37 am, edited 1 time in total.
Yeah, if you look at my log of esp_mesh_get_tsf_time() you can see that the first read also was slower than the rest. That's a bit unfortunate. Maybe it's worth opening a GitHub issue since it seems to be deterministic behavior.
Users browsing this forum: Baidu [Spider] and 7 guests
