Only validate image when anti-rollback is enabled?
Posted: Tue May 25, 2021 12:51 pm
I'm using the example "advanced_https_ota" as a base for my app development. Recently I've gotten more and more confused by about following code passage which is triggered in main() after successful wifi connection is established:
It seems that the app only validates when both directives, CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE and CONFIG_BOOTLOADER_APP_ANTI_ROLLBACK are set. However, the documentation clearly states the following:
#if defined(CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE) && defined(CONFIG_BOOTLOADER_APP_ANTI_ROLLBACK)
* We are treating successful WiFi connection as a checkpoint to cancel rollback
* process and mark newly updated firmware image as active. For production cases,
* please tune the checkpoint behavior per end application requirement.
const esp_partition_t *running = esp_ota_get_running_partition();
esp_ota_img_states_t ota_state;
if (esp_ota_get_state_partition(running, &ota_state) == ESP_OK) {
if (ota_state == ESP_OTA_IMG_PENDING_VERIFY) {
if (esp_ota_mark_app_valid_cancel_rollback() == ESP_OK) {
ESP_LOGI(TAG, "App is valid, rollback cancelled successfully");
} else {
ESP_LOGE(TAG, "Failed to cancel rollback");
#endifThus my question: Shouldn't I always confirm the image whenever CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE is set without the need for CONFIG_BOOTLOADER_APP_ANTI_ROLLBACK also to also be enabled? Is this a bug in the demo app?If the self-test has completed successfully, then you must call the function esp_ota_mark_app_valid_cancel_rollback() because the application is awaiting confirmation of operability (ESP_OTA_IMG_PENDING_VERIFY state).
