[已解决] 总是重启不知道如何是好了
Posted: Wed May 26, 2021 7:19 am
by c21945
LOG如下
[18:33:42.237]收←◆ets Jun 8 2016 00:22:57
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:7104
ho 0 tail 12 room 4
load:0x40078000,len:13204
load:0x40080400,len:4568
entry 0x400806f4
[0;32mI (63) boot: ESP-IDF v4.2 2nd stage bootloader[0m
[0;32mI (63) boot: compile time 18:25:06[0m
[0;32mI (63) boot: chip revision: 1[0m
[0;32mI (66) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m
[0;32mI (73) boot.esp32: SPI Speed : 40MHz[0m
[0;32mI (78) boot.esp32: SPI Mode : DIO[0m
[0;32mI (82) boot.esp32: SPI Flash Size : 4MB[0m
[0;33mW (87) boot.esp32: PRO CPU has been reset by WDT.[0m
[0;33mW (92) boot.esp32: WDT reset info: PRO CPU PC=0x400803c0[0m
[0;33mW (98) boot.esp32: WDT reset info: APP CPU PC=0x4014d682 (waiti mode)[0m
[0;32mI (105) boot: Enabling RNG early entropy source...[0m
[0;32mI (111) boot: Partition Table:[0m
[0;32mI (115) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (122) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m
[0;32mI (130) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (137) boot: 2 factory factory app 00 00 00010000 00100000[0m
[0;32mI (145) boot: End of partition table[0m
[0;32mI (149) boot_comm: chip revision: 1, min. application chip revision: 0[0m
[0;32mI (156) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1f64c (128588) map[0m
[0;32mI (214) esp_image: segment 1: paddr=0x0002f674 vaddr=0x3ffbdb60 size=0x009a4 ( 2468) load[0m
[0;32mI (215) esp_image: segment 2: paddr=0x00030020 vaddr=0x400d0020 size=0x7eb94 (519060) map[0m
[18:33:42.624]收←◆[0;32mI (418) esp_image: segment 3: paddr=0x000aebbc vaddr=0x3ffbe504 size=0x02e58 ( 11864) load[0m
[0;32mI (424) esp_image: segment 4: paddr=0x000b1a1c vaddr=0x40080000 size=0x00404 ( 1028) load[0m
[0;32mI (426) esp_image: segment 5: paddr=0x000b1e28 vaddr=0x40080404 size=0x162b8 ( 90808) load[0m
[18:33:42.691]收←◆[0;32mI (486) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (486) boot: Disabling RNG early entropy source...[0m
[0;32mI (487) cpu_start: Pro cpu up.[0m
[0;32mI (490) cpu_start: Application information:[0m
[0;32mI (495) cpu_start: Project name: esp32_air[0m
[0;32mI (500) cpu_start: App version: 23b1b6d-dirty[0m
[0;32mI (506) cpu_start: Compile time: May 25 2021 18:21:24[0m
[0;32mI (512) cpu_start: ELF file SHA256: 9013e923846d003b...[0m
[0;32mI (518) cpu_start: ESP-IDF: v4.2[0m
[0;32mI (522) cpu_start: Starting app cpu, entry point is 0x4008196c[0m
[0;32mI (0) cpu_start: App cpu up.[0m
[0;32mI (533) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (540) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM[0m
[0;32mI (546) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM[0m
[0;32mI (552) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM[0m
[0;32mI (558) heap_init: At 3FFC90B8 len 00016F48 (91 KiB): DRAM[0m
[0;32mI (564) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m
[0;32mI (570) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (577) heap_init: At 400966BC len 00009944 (38 KiB): IRAM[0m
[0;32mI (583) cpu_start: Pro cpu start user code[0m
[0;32mI (601) spi_flash: detected chip: gd[0m
[0;32mI (602) spi_flash: flash io: dio[0m
[0;32mI (602) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m
[0;32mI (630) MAIN: loading configuration from NVS[0m
[0;32mI (630) MAIN: bt device name is: 41R[0m
[0;32mI (630) BTDM_INIT: BT controller compile version [3723d5b][0m
[0;32mI (640) system_api: Base MAC address is not set[0m
[0;32mI (640) system_api: read default base MAC address from EFUSE[0m
[0;33mW (650) phy_init: failed to load RF
[18:33:42.875]收←◆ calibration data (0x1102), falling back to full calibration[0m
[18:33:43.791]收←◆ets Jun 8 2016 00:22:57
不断的来回重启,翻论坛是大多说是电源的事,我用大的ldo,加了电容,还是一样,也在 idf menuconfig 中去掉了,电压检查 还是一样
我该怎么办呢
Re: 总是重启不知道如何是好了
Posted: Wed May 26, 2021 8:49 am
by Gargamel
如果你不用 wifi & ble 会如何,看你 log 最后出问题的时候在做 rf cal,需要比较大的电流。
另外,每次重启都是 rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)?
Re: 总是重启不知道如何是好了
Posted: Wed May 26, 2021 11:21 am
by c21945
吧lod 放到芯片附件 就可以了,可能是电源线太细了,非常感谢!
