JTAG Connection - Missing RESET Pin in ESP-PROG
Posted: Mon May 31, 2021 10:54 pm
by javaska
Dear community, good afternoon
Going to use ESP-PROG with JTAG connection.
I would expect to connect RESET signal to the EN pin of my ESP32-WROOM-32D but can“t find it in the JTAG header of ESP-PROG.
Should I add external reset?
Thanks for your comments.
Best regards,
Re: JTAG Connection - Missing RESET Pin in ESP-PROG
Posted: Tue Jun 01, 2021 12:39 am
by Sprite
It depends - what do you want to use the ESP-PROG for? In general, we can reset the chip using JTAG commands, so for debugging it's not really necessary.
Posted: Tue Jun 01, 2021 1:14 pm
by javaska
Dear ESP_Sprite, good morning
Thanks for your reply.
I will be using JTAG for both debugging and flashing through JTAG. Should I connect anything on the EN pin of the device?.
Thanks again.
Best regards,
Posted: Tue Jun 01, 2021 1:33 pm
by Sprite
I don't have that much experience with flashing through JTAG, but I don't think so. (Well, outside of the power-on-reset circuit, see e.g. the devkitc schematics or the hardware guidelines for that.)
