I am new to using the device esp32 i want correct code
Posted: Fri Jun 04, 2021 11:16 am
by engjjd
hi
I am new to using the device esp32 i want correct code written for Arduino i want convert to esp32 Modula
int relayPinpv = 23;      // relay for phptovolatic panel
int relayPinbattery = 22;   // relay for battery
int relayPingrid2 =01;       // relay for Neighbors grid
int relayPintg = 19;          // relay for tradtional grid
int relayPingen = 23;          // relay for generator
float ppv=600 ;
float pbattery=600 ;
float pgrid2 ;
float vtg ;
float pt= 500 ;       //load power 500 W
void setup() {
  pinMode(relayPinpv, OUTPUT);
    pinMode(relayPinbattery, OUTPUT);
      pinMode(relayPingrid2, OUTPUT);
        pinMode(relayPintg, OUTPUT);
        pinMode(relayPingen, OUTPUT);
void loop() {
  if (ppv>= pt) {
  digitalWrite(relayPinpv, HIGH);
  digitalWrite(relayPintg, LOW);
  digitalWrite(relayPinbattery, LOW);
  digitalWrite(relayPingrid2, LOW);
else if ((ppv<pt)&&((ppv+pbattery)>= pt))
  digitalWrite(relayPinbattery, HIGH);
else if ((ppv<pt)&&((ppv+pbattery)<pt)&&((ppv+pbattery+pgrid2)>= pt))
  digitalWrite(relayPingrid2, HIGH);
else if (vtg >0) {
  digitalWrite(relayPintg, HIGH);
  digitalWrite(relayPinpv, LOW);
else {
  digitalWrite(relayPingen, HIGH);
  delay(1000);
Re: I am new to using the device esp32 i want correct code
Posted: Fri Jun 04, 2021 3:04 pm
by Minatel
What exactly you are looking for?
Posted: Thu Jul 29, 2021 2:58 pm
by mbratch
Could you clarify what you mean by "...convert to ESP32 Modula"? Modula is a programming language developed in the 1970's.
Do you mean to convert to ESP-IDF? If so, then install ESP-IDF per their instructions on the espressif.com site, and look at the basic examples to see how programs are structured.
