This problem is about the Arduino-ESP32 Rainmaker demo
fary_young
Postby fary_young » Fri Jun 18, 2021 1:55 am
I tried to use the Rainmaker example provided by Arduino-ESP32, but when I ran it, I printed out the result like this. How can I solve this problem?
Piyush
Re: This problem is about the Arduino-ESP32 Rainmaker demo
Postby Piyush » Fri Jun 18, 2021 2:50 am
Seems that your board already had the Wi-Fi credentials stored in the persistent memory (NVS) while your programmed it with the ESP RainMaker firmware. Please press and hold the BOOT button for more than 3 seconds and then release so that the credentials get erased . Thereafter, repeat the provisioning using the ESP RainMaker phone apps.
fary_young
Postby fary_young » Fri Jun 18, 2021 10:39 am
Hello, thank you for your answer. After trying according to your method, the QR code can be successfully output, but the style interval of the QR code is too large to identify the information. How should I solve this problem?
John__
Contact:
Postby John__ » Sun Jun 27, 2021 5:16 am
Hi there, It looks like you are using windows. The serial monitor on windows cannot properly display the 2D barcode but there are 2 solutions:
1. Use a different serial monitor as I did here: https://youtu.be/g-Mw0-lzxdg
2. Enter the credentials manually as I mention in this video: https://youtu.be/g-Mw0-lzxdg
Hope this helps :)
marcelstoer
Postby marcelstoer » Fri Jul 09, 2021 8:49 am
Right below the QR code you should also see a URL that you can paste into any browser. I will render the same QR code there.
Baruna1221
Postby Baruna1221 » Mon Jun 03, 2024 10:02 am
Why my serial monitor in arduino ide cannot display qrcode? I already install library esp32, etc
This is my serial monitor in arduino ide
