Bluetooth A2DP Source example? (ESP32 streaming to BT speaker)
Posted: Wed Jun 14, 2017 1:29 pm
by fesp32@joov.de
I understand that the ESP32 uses the Bluedroid Stack which apparently supports A2DP Source and Sink services (please correct me if this is wrong).
The esp-idf contains an a2dp_sink example which works.
If have the following questions:
- Can the ESP32 also act as an audio source, i.e. A2DP Source?
- Is there any example of that? I am looking at the Bluedroid APIs but I do not have the slightest clue how to configure the ESP32 as an A2DP Source.
- Blue sky question: Is the ESP32 able to connect to two separate Bluetooth Speakers and stream audio to them? Is this doable using the Blueddroid stack?
Any hints welcome.
Cheers,
Johannes
Re: Bluetooth A2DP Source example? (ESP32 streaming to BT speaker)
Posted: Wed Jun 14, 2017 2:05 pm
by rudi ;-)
Any hints welcome.
hi johannes
(transceiver) (A2DP-SRC: Advanced Audio Distribution Source)
(receiver) (A2DP-SNK: Advanced Audio Distribution Sink)
what we have just in time as example is A2DP-SNK as ESP_SPEAKER
what you search is A2DP-SRC , i think there is just in time no example available.
Posted: Tue Sep 05, 2017 1:19 am
by CrabbyPete
There may be no example, but is it able to be done?
Posted: Sat Apr 25, 2020 5:31 am
by omario_ii
I stumbled upon this:
https://github.com/gtalusan/esp-idf/tre ... 2dp_source
Never tested but author says it is an implementation of A2DP-SRC
Posted: Mon Feb 15, 2021 2:11 pm
by nopnop2002
Try this.
https://github.com/nopnop2002/esp-idf-a2dp-source
You can listen to WAV with your bluetooth speaker.
