经典蓝牙广播数据问题
Posted: Thu Jun 24, 2021 2:36 am
by mryboy
模块:ESP32-WROVER-B
IDF:release/v4.3
协议:经典蓝牙,GAP+SPP
需求:蓝牙广播的时候传递信息
问题描述:没有找到这种需求的例程,发现GAP的API中esp_bt_gap_config_eir_data可以配置数据,广播时能收到。一开始include_uuid设置为false,发现电脑上接收到一个manufacturer数据包,数据比manufacturer_len配置的大小少2个字节,而且配置的长度大于50个字节后就无效了;include_uuid设置为true能收到两个manufacturer数据包,一个是26字节,一个是20字节,第一个的数据是缓冲区配置的,第二个的数据不知道哪里来的。完全不懂这个函数和这个结构体的使用,在例程和IDF的文档上也没有相关资料,请求帮助,或者有什么其它在广播时设备给电脑传递信息的方法也行。
#define ESP_BT_EIR_MAX_LEN                  240
/// EIR data content, according to "Supplement to the Bluetooth Core Specification"
typedef struct {
    bool                    fec_required;           /*!< FEC is required or not, true by default */
    bool                    include_txpower;        /*!< EIR data include TX power, false by default */
    bool                    include_uuid;           /*!< EIR data include UUID, false by default */
    uint8_t                 flag;                   /*!< EIR flags, see ESP_BT_EIR_FLAG for details, EIR will not include flag if it is 0, 0 by default */
    uint16_t                manufacturer_len;       /*!< Manufacturer data length, 0 by default */
    uint8_t                 *p_manufacturer_data;   /*!< Manufacturer data point */
    uint16_t                url_len;                /*!< URL length, 0 by default */
    uint8_t                 *p_url;                 /*!< URL point */
} esp_bt_eir_data_t;
 * @brief           This function is called to config EIR data.
 *                  esp_bt_gap_cb_t will be called with ESP_BT_GAP_CONFIG_EIR_DATA_EVT after config EIR ends.
 * @param[in]       eir_data - pointer of EIR data content
 * @return
 *                  - ESP_OK : Succeed
 *                  - ESP_ERR_INVALID_STATE: if bluetooth stack is not yet enabled
 *                  - ESP_ERR_INVALID_ARG: if param is invalid
 *                  - ESP_FAIL: others
esp_err_t esp_bt_gap_config_eir_data(esp_bt_eir_data_t *eir_data);
Re: 经典蓝牙广播数据问题
Posted: Fri Jun 25, 2021 4:01 am
by Boblane
mryboy 你好,
根据蓝牙核心协议 Core_spec_v4.2 [Vol3, Part C] 第八章的介绍,EIR data 部分总长 240 字节,按照 length-type-value 的格式排列。如下图所示:
目前 ESP32 上支持的 EIR type 有:
Code: Untitled.c Select all
/// Extended Inquiry Response data type
#define ESP_BT_EIR_TYPE_FLAGS 0x01 /*!< Flag with information such as BR/EDR and LE support */
#define ESP_BT_EIR_TYPE_INCMPL_16BITS_UUID 0x02 /*!< Incomplete list of 16-bit service UUIDs */
#define ESP_BT_EIR_TYPE_CMPL_16BITS_UUID 0x03 /*!< Complete list of 16-bit service UUIDs */
#define ESP_BT_EIR_TYPE_INCMPL_32BITS_UUID 0x04 /*!< Incomplete list of 32-bit service UUIDs */
#define ESP_BT_EIR_TYPE_CMPL_32BITS_UUID 0x05 /*!< Complete list of 32-bit service UUIDs */
#define ESP_BT_EIR_TYPE_INCMPL_128BITS_UUID 0x06 /*!< Incomplete list of 128-bit service UUIDs */
#define ESP_BT_EIR_TYPE_CMPL_128BITS_UUID 0x07 /*!< Complete list of 128-bit service UUIDs */
#define ESP_BT_EIR_TYPE_SHORT_LOCAL_NAME 0x08 /*!< Shortened Local Name */
#define ESP_BT_EIR_TYPE_CMPL_LOCAL_NAME 0x09 /*!< Complete Local Name */
#define ESP_BT_EIR_TYPE_TX_POWER_LEVEL 0x0a /*!< Tx power level, value is 1 octet ranging from -127 to 127, unit is dBm*/
#define ESP_BT_EIR_TYPE_URL 0x24 /*!< Uniform resource identifier */
#define ESP_BT_EIR_TYPE_MANU_SPECIFIC 0xff /*!< Manufacturer specific data */
#define ESP_BT_EIR_TYPE_MAX_NUM 12 /*!< MAX number of EIR type */
可以看到其中的一些类型,与 esp_bt_eir_data_t 能对应的上,目前,没有接口去直接设置 UUID 的值。
我在 demo esp_spp_acceptor/example_spp_acceptor_demo.c 中添加了如下代码:
static uint8_t manufacturer_data[60] = {
0x00, 0x02, 0x00, 0x04, 0x00, 0x06, 0x00, 0x08, 0x00, 0x0a, 0x00, 0x0c, 0x00, 0x0e, 0x00,
0x10, 0x00, 0x12, 0x00, 0x14, 0x00, 0x16, 0x00, 0x18, 0x00, 0x1a, 0x00, 0x1c, 0x00, 0x1e,
0x00, 0x20, 0x00, 0x22, 0x00, 0x24, 0x00, 0x26, 0x00, 0x28, 0x00, 0x2a, 0x00, 0x2c, 0x00,
0x2e, 0x00, 0x30, 0x00, 0x32, 0x00, 0x34, 0x00, 0x36, 0x00, 0x38, 0x00, 0x3a, 0x00, 0x3c,
static esp_bt_eir_data_t eir_data;
void app_main(void)
if ((ret = esp_bt_gap_register_callback(esp_bt_gap_cb)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s gap register failed: %s\n", __func__, esp_err_to_name(ret));
return;
eir_data.fec_required = true;
eir_data.include_uuid = true;
eir_data.flag = ESP_BT_EIR_FLAG_GEN_DISC | ESP_BT_EIR_FLAG_DMT_CONTROLLER_SPT | ESP_BT_EIR_FLAG_DMT_HOST_SPT;
eir_data.manufacturer_len = 60;
eir_data.p_manufacturer_data = manufacturer_data;
if ((ret = esp_bt_gap_config_eir_data(&eir_data)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s gap config eir data failed: %s\n", __func__, esp_err_to_name(ret));
return;
if ((ret = esp_spp_register_callback(esp_spp_cb)) != ESP_OK) {
ESP_LOGE(SPP_TAG, "%s spp register failed: %s\n", __func__, esp_err_to_name(ret));
return;
在 demo esp_spp_initiator/main/example_spp_initiator_demo.c 中添加了如下代码:
static void esp_bt_gap_cb(esp_bt_gap_cb_event_t event, esp_bt_gap_cb_param_t *param)
switch(event){
case ESP_BT_GAP_DISC_RES_EVT:
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_DISC_RES_EVT");
esp_log_buffer_hex(SPP_TAG, param->disc_res.bda, ESP_BD_ADDR_LEN);
for (int i = 0; i < param->disc_res.num_prop; i++){
if (param->disc_res.prop[i].type == ESP_BT_GAP_DEV_PROP_EIR
&& get_name_from_eir(param->disc_res.prop[i].val, peer_bdname, &peer_bdname_len)){
esp_log_buffer_char(SPP_TAG, peer_bdname, peer_bdname_len);
if (strlen(remote_device_name) == peer_bdname_len &&
strncmp(peer_bdname, remote_device_name, peer_bdname_len) == 0) {
uint8_t *eir_val = NULL;
uint8_t eir_len = 0;
for (int type = 0; type <= ESP_BT_EIR_TYPE_MANU_SPECIFIC; type++) {
switch (type) {
case ESP_BT_EIR_TYPE_FLAGS:
case ESP_BT_EIR_TYPE_INCMPL_16BITS_UUID:
case ESP_BT_EIR_TYPE_CMPL_16BITS_UUID:
case ESP_BT_EIR_TYPE_INCMPL_32BITS_UUID:
case ESP_BT_EIR_TYPE_CMPL_32BITS_UUID:
case ESP_BT_EIR_TYPE_INCMPL_128BITS_UUID:
case ESP_BT_EIR_TYPE_CMPL_128BITS_UUID:
case ESP_BT_EIR_TYPE_TX_POWER_LEVEL:
case ESP_BT_EIR_TYPE_URL:
case ESP_BT_EIR_TYPE_MANU_SPECIFIC:
eir_val = esp_bt_gap_resolve_eir_data(param->disc_res.prop[i].val, type, &eir_len);
break;
default:
break;
if (eir_val) {
switch (type) {
printf("--FLAGS len:%d\n", eir_len);
esp_log_buffer_hex(" FLAGS", eir_val, eir_len);
break;
printf("--INCMPL_16BITS_UUID len:%d\n", eir_len);
esp_log_buffer_hex(" INCMPL_16BITS_UUID", eir_val, eir_len);
break;
printf("--CMPL_16BITS_UUID len:%d\n", eir_len);
esp_log_buffer_hex(" CMPL_16BITS_UUID", eir_val, eir_len);
break;
printf("--INCMPL_32BITS_UUID len:%d\n", eir_len);
esp_log_buffer_hex(" INCMPL_32BITS_UUID", eir_val, eir_len);
break;
printf("--CMPL_32BITS_UUID len:%d\n", eir_len);
esp_log_buffer_hex(" CMPL_32BITS_UUID", eir_val, eir_len);
break;
printf("--INCMPL_128BITS_UUID len:%d\n", eir_len);
esp_log_buffer_hex(" INCMPL_128BITS_UUID", eir_val, eir_len);
break;
printf("--CMPL_128BITS_UUID len:%d\n", eir_len);
esp_log_buffer_hex(" CMPL_128BITS_UUID", eir_val, eir_len);
break;
printf("--TX_POWER_LEVEL len:%d\n", eir_len);
esp_log_buffer_hex(" TX_POWER_LEVEL", eir_val, eir_len);
break;
printf("--URL len:%d\n", eir_len);
esp_log_buffer_hex(" URL", eir_val, eir_len);
break;
printf("--MANU_SPECIFIC len:%d\n", eir_len);
esp_log_buffer_hex(" MANU_SPECIFIC", eir_val, eir_len);
break;
default:
break;
memcpy(peer_bd_addr, param->disc_res.bda, ESP_BD_ADDR_LEN);
esp_spp_start_discovery(peer_bd_addr);
esp_bt_gap_cancel_discovery();
break;
case ESP_BT_GAP_DISC_STATE_CHANGED_EVT:
ESP_LOGI(SPP_TAG, "ESP_BT_GAP_DISC_STATE_CHANGED_EVT");
break;
GAP discovery 的结果如 discovery_res.png 所示,同时电脑上用 wireshark 对 dongle 抓包的结果如 cap.png 所示。两边均接收到 60 字节的 manufacturer_data 数据。
