Hi ESP Community,
I am working on communicating between two ESP32-WROOM-32 microcontrollers using SDIO Host and Slave. As examples already given in ESP IDF. After hardware connection as given in that example, I am getting the following output
I (310) cpu_start: Starting scheduler on PRO CPU.
I (321) example_slave: ================ slave ready ================
I want to know the next step to get the buffer output on serial monitor. (from host to slave).
Communication between 2 ESP controllers using SDIO (ESP32<->SDIO<->ESP32).
Re: Communication between 2 ESP controllers using SDIO (ESP32<->SDIO<->ESP32).
Did you find any solution, I am getting same issue. Slave side, I am getting "slave ready" but at host I am getting "failed to initialize slave".
