hello, although I suppose you have already thought about it, an alternative way is that the app installed on the client's smarphone, configure the phone as AP wifi with some keys that ESP knows and pressing, for example, the reset of ESP this connects to the smartphone and updates.
Greetings,
ESP32 OTA via BLE
Re: ESP32 OTA via BLE
hi folks,
we tried implementing OTA over BLE ( product requirement), 700KB taking around 52 minutes .. roughly 200 bytes per second with long write.
could anyone advise what could possibly wrong.. we built data transfer rate over the gattt_server example code.
i see in the websites that we could hit upto 2K with BLE, any one could explain how to get that rates?
ios is not allowing write without response. please help me folks, we are in a dire need to speed up with data rates.
Resolved by changing the MTU to 500 from client
Also try making your connection interval shorter. this may improve the transfer time.
Out of curiosity approximately what is the update time once you increased the MTU to 500?
it is around 5 minutes 720K
hi,
I'm doing related BLE OTA functions. Has anyone made any suggestions ? Now I am looking at the DFU of Nordic to find some solutions.
I just measured. It takes me less than 30 sek to OTA update over BLE with MTU 512 and file size around 950kB.
I dont know if can advice or disadvice to use DFU, because i dont know it. I only know its nordic semiconductor proprietary protocol and you would have to learn how it works to implement it on esp32. I know its sending notifications with data and peer device has to send back CRC, not every received packet but i dont know how often. There is for sure going on more in that protocol, but that all i know right now.xiaoyao wrote: hi,
I am using OTA over BLE a lot and its custom made implementation and it works good to me.
Hi, I am quite interested in this. I just did a very basic test, no optimization at all writing to a gatt characteristic that just discards the data and getting about 1kB/s which seems extremely low. Could you share some info on your setup?I just measured. It takes me less than 30 sek to OTA update over BLE with MTU 512 and file size around 950kB.
I'm also using BLE for OTA update, but it takes about 7 minutes for a full update at that speed, 1-2 min for differential update.
Simple code, using Kolban's library, the same which is in arduino-esp32. No CRC or any other error correction, sending with notifications, MTU 512. Client app to OTA update is ionic on android, iOS app is using max 185 MTU and update is longer accordingly.
I am using it in few projects, also commercial projects.
Users browsing this forum: Bing [Bot] and 54 guests
