Boot failure on ESP32-C3
__SG-O
Postby __SG-O » Wed Jul 21, 2021 11:09 am
I'm trying to run some example code on the ESP32-C3-DevKitM-1. I'm using a custom partition table without a factory partition. I get this output on boot.
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x1808
load:0x403ce000,len:0x8d4
load:0x403d0000,len:0x293c
SHA-256 comparison failed:
Calculated: 7cb7c23f0a1c7b6e3529c0800364848023bc18b8e8e43a60f3a343a940a1be8d
Expected: b579f259292fa809601c5c5d254f5e2097bb94fe0df1423ed61394178e4d0332
Attempting to boot anyway...
entry 0x403ce000
␛[0;32mI (48) boot: ESP-IDF 4.3.0 2nd stage bootloader␛[0m
␛[0;32mI (49) boot: compile time 12:35:22␛[0m
␛[0;32mI (49) boot: chip revision: 3␛[0m
␛[0;32mI (50) boot_comm: chip revision: 3, min. bootloader chip revision: 0␛[0m
␛[0;32mI (57) boot.esp32c3: SPI Speed      : 80MHz␛[0m
␛[0;32mI (62) boot.esp32c3: SPI Mode       : DIO␛[0m
␛[0;32mI (67) boot.esp32c3: SPI Flash Size : 4MB␛[0m
␛[0;32mI (71) boot: Enabling RNG early entropy source...␛[0m
␛[0;32mI (77) boot: Partition Table:␛[0m
␛[0;32mI (80) boot: ## Label            Usage          Type ST Offset   Length␛[0m
␛[0;32mI (88) boot:  0 nvs              WiFi data        01 02 00009000 00004000␛[0m
␛[0;32mI (95) boot:  1 otadata          OTA data         01 00 0000d000 00002000␛[0m
␛[0;32mI (103) boot:  2 phy_init         RF data          01 01 0000f000 00001000␛[0m
␛[0;32mI (110) boot:  3 ota_0            OTA app          00 10 00010000 00100000␛[0m
␛[0;32mI (118) boot:  4 ota_1            OTA app          00 11 00110000 00100000␛[0m
␛[0;32mI (125) boot:  5 spiffs           Unknown data     01 82 00210000 001e0000␛[0m
␛[0;32mI (133) boot:  6 nvs_key          NVS keys         01 04 003f0000 00001000␛[0m
␛[0;32mI (140) boot: End of partition table␛[0m
␛[0;32mI (145) boot_comm: chip revision: 3, min. application chip revision: 0␛[0m
␛[0;32mI (152) esp_image: segment 0: paddr=00010020 vaddr=3c090020 size=17f08h ( 98056) map␛[0m
␛[0;32mI (176) esp_image: segment 1: paddr=00027f30 vaddr=3fc8d600 size=03428h ( 13352) load␛[0m
␛[0;32mI (178) esp_image: segment 2: paddr=0002b360 vaddr=40380000 size=04cb8h ( 19640) load␛[0m
␛[0;32mI (185) esp_image: segment 3: paddr=00030020 vaddr=42000020 size=8e6c0h (583360) map␛[0m
␛[0;32mI (281) esp_image: segment 4: paddr=000be6e8 vaddr=40384cb8 size=088ach ( 34988) load␛[0m
␛[0;32mI (288) esp_image: segment 5: paddr=000c6f9c vaddr=50000000 size=00010h (    16) load␛[0m
␛[0;32mI (292) boot: Loaded app from partition at offset 0x10000␛[0m
␛[0;32mI (293) boot: Disabling RNG early entropy source...␛[0m
␛[0;32mI (310) cpu_start: Pro cpu up.␛[0m
ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x7 (TG0WDT_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x40380084
SPIWP:0xee
entry 0x403ce000
␛[0;32mI (53) boot: ESP-IDF 4.3.0 2nd stage bootloader␛[0m
␛[0;32mI (53) boot: compile time 12:35:22␛[0m
␛[0;32mI (53) boot: chip revision: 0␛[0m
␛[0;31mE (55) boot_comm: mismatch chip ID, expected 5, found 65535␛[0m
␛[0;31mE (61) boot_comm: This chip is revision 0 but the application is configured for minimum revision 255. Can't run.␛[0m
Build:Feb  7 2021
Saved PC:0x403d11a0
SPIWP:0xee
entry 0x403ce000
Thanks for any advice.
__SG-O
Re: Boot failure on ESP32-C3
Postby __SG-O » Fri Jul 23, 2021 10:09 am
I can't get code working on the ESP32-C3... I'm now using the development branch and followed this guide: https://github.com/espressif/vscode-esp ... sic_use.md. I didn't change the default configuration. After flashing to the ESP32-C3-DevKitM-1 (Seems to work fine) I perform a reset and get the following output:
Build:Feb  7 2021
SPIWP:0xee
load:0x3fcd6100,len:0x15cc
load:0x403ce000,len:0x93c
load:0x403d0000,len:0x292c
Calculated: 17cc57fea7eea45ac2e9bf9bdefdefaa943d03085ce90fa329830ce9550827c9
Expected: d451a61637192f385c45e25933cd5be994cdc7c68e65be0e05476abc350b59ea
entry 0x403ce000
I (48) boot: ESP-IDF v4.4-dev-2184-g166c30e7b 2nd stage bootloader
I (49) boot: compile time 12:02:36
I (52) boot.esp32c3: SPI Speed      : 80MHz
I (57) boot.esp32c3: SPI Mode       : DIO
I (61) boot.esp32c3: SPI Flash Size : 4MB
I (66) boot: Enabling RNG early entropy source...
I (71) boot: Partition Table:
I (75) boot: ## Label            Usage          Type ST Offset   Length
I (82) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (90) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (97) boot:  2 factory          factory app      00 00 00010000 00100000
I (105) boot: End of partition table
I (109) esp_image: segment 0: paddr=00010020 vaddr=3c020020 size=076f8h ( 30456) map
I (122) esp_image: segment 1: paddr=00017720 vaddr=3fc8b000 size=013f8h (  5112) load
I (127) esp_image: segment 2: paddr=00018b20 vaddr=40380000 size=074f8h ( 29944) load
I (140) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=17d08h ( 97544) map
I (158) esp_image: segment 4: paddr=00037d30 vaddr=403874f8 size=039ach ( 14764) load
I (161) esp_image: segment 5: paddr=0003b6e4 vaddr=50000000 size=00010h (    16) load
I (167) boot: Loaded app from partition at offset 0x10000
I (170) boot: Disabling RNG early entropy source...
I (187) cpu_start:@Pro cpu up.�ESP-ROM:esp32c3-api1-20210207
ESP-RO�ESP-ROM:esp32c3-api1-20210207
MA�ROM:esp32c3-api1-20210207
ESP-ROMESP-ROM:esp32c3-api1-20210207
ESP-ROM�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:e
ESP-ROM:eESP-ROM:esp32c3-api1-20210207
ESP-ROM:�EGA�ROM:esp32c3-api1-20210207
E�P-ROM:esp32c3-api1-20210207
ŧP-ROM:esp32c3-api1-20210207
ESP-ROM:e�ESP-ROM:esp32c3-api1-20210207
�6Ւ=5�esp32c3-api1-20210207
ESP-ROM:esp32���SP-ROM:esp32c3-api1-20210207
�MA�ROM:esp32c3-api1-20210207
ESP-ROM:esESP-ROM:esp32c3-api1-20210207
ESP-ROM:es�ESP-ROM:esp�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32c3a4�SP-ROM:esp32c3-api1-20210207
ESP-ROM:espESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32cc�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32c3�H���-20210207
Build�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32c�N)���j��������j
Build�ESP-ROM:esp�ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOO�ESP-ROM:esp3ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)�ESP-ROM:e�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:es�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32��ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT�ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT�ESP-ROM:es�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32c�-apiaESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32c�j
���ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT�ESP-ROM:e�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esESP-ROM:esp32�j
���j��������j
Build�ESP-ROM:esESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT�ESP-ROM:es�ESP-ROM:esp32�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esESP-ROM:es�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32ùESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)ESP-ROM:es�ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
ESP-ROM:esp32�-ap��ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp3bc3-api1-20210207
Build:�ESP-ROM:esESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
�ESP-ROM:e�ESP-ROM:esp32c3-api1-20210207SH_BOOT)
ESP-ROM:e�ESP-ROM:esp3�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp3��ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)�ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32�ESP-ROM:es�ESP-ROM:esp32Ùj
�ESP-ROM:espESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32�j
ESP-ROM:es�ESP-ROM:esp32��ESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp3�6�-��ESP-ROM:esESP-ROM:esp32c3-api1-20210207
ESP-ROM:esp32ESP-ROM:esp32c3-api1-20210207
ESP-ROM:ESP-ROM:esp32c3-api1-20210207
ESP-ROM:�ESP-R�ESP-ROM:esp32c3-api1-20210207
ESP-ESP-ROy�*���2
                 �-api1-20210207
ESP-ROy�ESP-ROM:esp32c3-api1-20210207
ES�ESP-ROM:esp32c3-api1-20210207
ESP-R���ESP-ROM:esp32c3-api1-20210207
ES�ES�ESP-ROM:esp32c3-api1-20210207
ESESP-ROM:esp32c3-api1-20210207
ESP-R>�ESP-ROM:esp32c3-api1-20210207
B�E�ESP-�ESP-ROM:esp32c3-api1-20210207
Bui�ESP-ROM:esp32c3-api1-20210207
ESP-ROESP-ROM:esp32c3-api1-20210207
ESPMESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
SPI�A�0xee
m�ESESP�ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH��ESP-ROM:esp32c3-api1-20210207
ESP-�ES�ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (�E�ESP-ROMESP-ROM:esp32c3-api1-202ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),b�ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POW�ESP-ROM:esp32c�ESP-ROM:esp32c3-api1-202�ESP-ROM:esp32c3-api1-20210207
Build:Fe�ESP-ROM:esp32c3�ESP-ROM:esp32c3-api1-202102�ESP-ROM:esp32c3-api1-202102�ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FASESP-ROM:esp32c3-api1-20210207�ES�ESP-ROMESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
SPIWP:0xee
entry 0x403ce000
I (49) boot: chip revision: 0
E (52) boot_comm: mismatch chip ID, expected 5, found 65535
E (58) boot_comm: This chip is revision 0 but the application is configured for minimum revision 255. Can't run.
Build:Feb  7 2021
Saved PC:0x403d1198
SPIWP:0xee
entry 0x403ce000
I (53) boot: ESP-IDF v4.4-dev-2184-g166c30e7b 2nd stage bootloader
I (53) boot: compile time 12:02:36
I (54) boot: chip revision: 0
E (57) boot_comm: mismatch chip ID, expected 5, found 65535
E (63) boot_comm: This chip is revision 0 but the application is configured for minimum revision 255. Can't run.
Build:Feb  7 2021
Saved PC:0x403d1198
SPIWP:0xee
entry 0x403ce000
Build:Feb  7 2021
Saved PC:0x403d1198
SPIWP:0xee
entry 0x403ce000
Build:Feb  7 2021
Saved PC:0x403d1198
SPIWP:0xee
entry 0x403ce000
Postby Sprite » Fri Jul 23, 2021 2:49 pm
Feels like some sort of power issue... can you try using a different USB cable or powering the board from an external power supply?
__SG-O
Postby __SG-O » Fri Jul 23, 2021 3:30 pm
I tried different USB cables and Ports and this didn't help.
I now tried a second ESP32-C3-DevKitM-1 devkit which I modified to use the Integrated USB serial/JTAG debug controller. Booting / Blinking works fine here.
Probably something is wrong with the external USB serial converter or the ESP32-C3-MINI-1 on the board I tested on originally.
lukedukeusa
Postby lukedukeusa » Wed Feb 23, 2022 11:51 pm
How did you do this / what did you do? I am still having the same issue.
esp32c3
Postby esp32c3 » Sun May 15, 2022 12:00 pm
Users browsing this forum: Applebot, Baidu [Spider], Bytespider, ChatGPT-User, meta-externalagent, PerplexityBot and 3 guests
