When I want to initialize and start the
WiFi Access Point I use this piece of code:
Code: Untitled.cpp Select all
void wifi_init_softap(void){
esp_netif_ip_info_t ipInfo;
esp_netif_t* wifiAP = esp_netif_create_default_wifi_ap();
IP4_ADDR(&ipInfo.ip, 192,168,2,1);
IP4_ADDR(&ipInfo.gw, 192,168,2,1);
IP4_ADDR(&ipInfo.netmask, 255,255,255,0);
esp_netif_dhcps_stop(wifiAP);
esp_netif_set_ip_info(wifiAP, &ipInfo);
esp_netif_dhcps_start(wifiAP);
ESP_LOGI(TAG, "IP: " IPSTR, IP2STR(&ipInfo.ip));
ESP_LOGI(TAG, "GW: " IPSTR, IP2STR(&ipInfo.gw));
ESP_LOGI(TAG, "Mask: " IPSTR, IP2STR(&ipInfo.netmask));
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL));
wifi_config_t wifi_config = {
.ap = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.ssid_len = strlen(EXAMPLE_ESP_WIFI_SSID),
.password = EXAMPLE_ESP_WIFI_PASS,
.max_connection = EXAMPLE_MAX_STA_CONN,
.authmode = WIFI_AUTH_WPA_WPA2_PSK
if (strlen(EXAMPLE_ESP_WIFI_PASS) == 0) {
wifi_config.ap.authmode = WIFI_AUTH_OPEN;
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
ESP_LOGI(TAG, "wifi_init_softap finished. SSID:%s password:%s", EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
It works correctly.
However I assume I have the functionality that permit the switch from access point to station.
Here the code I used to initialize and start my
WiFi station (NOTE: by doing this way, the active AP will deactivate itself):
esp_err_t make_sta_handler(httpd_req_t *req){
ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
s_wifi_event_group = xEventGroupCreate();
ESP_ERROR_CHECK(esp_wifi_stop());
//ESP_ERROR_CHECK(esp_netif_init());
//ESP_ERROR_CHECK(esp_event_loop_create_default());
esp_netif_create_default_wifi_sta();
esp_event_handler_instance_t instance_any_id;
esp_event_handler_instance_t instance_got_ip;
ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT, ESP_EVENT_ANY_ID,
&event_handler, NULL, &instance_any_id));
ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT, IP_EVENT_STA_GOT_IP,
&event_handler, NULL, &instance_got_ip));
.sta = {
.ssid = ESP_WIFI_SSID,
.password = ESP_WIFI_PASS,
/* Setting a password implies station will connect to all security modes including WEP/WPA.
* However these modes are deprecated and not advisable to be used. Incase your Access point
* doesn't support WPA2, these mode can be enabled by commenting below line */
.threshold.authmode = WIFI_AUTH_WPA2_PSK,
.pmf_cfg = {
.capable = true,
.required = false
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config));
ESP_LOGI(TAG, "wifi_init_sta finished.");
EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group, WIFI_CONNECTED_BIT | WIFI_FAIL_BIT, pdFALSE,
pdFALSE, portMAX_DELAY);
/* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
* happened. */
if (bits & WIFI_CONNECTED_BIT) {
ESP_LOGI(TAG, "connected to ap SSID:%s password:%s", ESP_WIFI_SSID, ESP_WIFI_PASS);
else if (bits & WIFI_FAIL_BIT) {
ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s", ESP_WIFI_SSID, ESP_WIFI_PASS);
else {
ESP_LOGE(TAG, "UNEXPECTED EVENT");
/* The event will not be processed after unregister */
ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
vEventGroupDelete(s_wifi_event_group);
return ESP_OK;
Let's suppose I want to switch back to AP mode, and then to STA mode, and so on all the times I want and I need.
I'm sure I don't need to initialize always all the protocols (in fact I obtain errors).
On the other hand, I don't understand what exactly I have to do.
My question is: What are the pieces of code I don't need when switching the modalities?
