Receive Vendor Specific Action frame without enabling sniffer mode
deadlock
Postby deadlock » Sun Aug 01, 2021 6:46 pm
Hi
I am running softap and I am trying to implement a special protocol and parts of it implies that I need to listen for a Vendor Specific Action frame. Is the only way to enable sniffer mode?
Sniffer mode seems very unconvenient and power hungry so I would like to avoid it if possible.
Since the packet is directed to my esp32 I would think that there should be some kind of callback I could use to get the data. Is there such a callback or is sniffer mode my only option?
Kind regards
Jens
deadlock
Re: Receive Vendor Specific Action frame without enabling sniffer mode
Postby deadlock » Mon Aug 02, 2021 11:03 pm
And even sniffer mode does not seem to be sufficient. I can see the Action Frame in Wireshark but I cannot receive them in sniffer mode with the esp32... Can this be a bug?
This is how I set up sniffer mode:
void wifi_init_sniffer(void) {
  const wifi_promiscuous_filter_t filt = {
      .filter_mask = WIFI_EVENT_MASK_ALL
  ESP_ERROR_CHECK(esp_wifi_set_promiscuous_filter(&filt));
  ESP_ERROR_CHECK(esp_wifi_set_promiscuous_rx_cb(wifi_sniffer_packet_handler));
  ESP_ERROR_CHECK(esp_wifi_set_promiscuous(true));
Here is a dump from Wireshark on one of the action frames I do not see in sniffer mode
IEEE 802.11 wireless LAN management frame
    Fixed parameters (12 bytes)
        Timestamp: 0x000000000c6892a1
        Beacon Interval: 0.102400 [Seconds]
        Capabilities Information: 0x0431
            .... .... .... ...1 = ESS capabilities: Transmitter is an AP
            .... .... .... ..0. = IBSS status: Transmitter belongs to a BSS
            .... ..0. .... 00.. = CFP participation capabilities: No point coordinator at AP (0x0000)
            .... .... ...1 .... = Privacy: AP/STA can support WEP
            .... .... ..1. .... = Short Preamble: Allowed
            .... .... .0.. .... = PBCC: Not Allowed
            .... .... 0... .... = Channel Agility: Not in use
            .... ...0 .... .... = Spectrum Management: Not Implemented
            .... .1.. .... .... = Short Slot Time: In use
            .... 0... .... .... = Automatic Power Save Delivery: Not Implemented
            ...0 .... .... .... = Radio Measurement: Not Implemented
            ..0. .... .... .... = DSSS-OFDM: Not Allowed
            .0.. .... .... .... = Delayed Block Ack: Not Implemented
            0... .... .... .... = Immediate Block Ack: Not Implemented
    Tagged parameters (239 bytes)
        Tag: SSID parameter set: DIRECT-XX-deadlock
            Tag Number: SSID parameter set (0)
            Tag length: 20
            SSID: DIRECT-XX-deadlock
        Tag: Supported Rates 5.5(B), 11(B), 1(B), 2(B), 6, 12, 24, 48, [Mbit/sec]
            Tag Number: Supported Rates (1)
            Tag length: 8
            Supported Rates: 5.5(B) (0x8b)
            Supported Rates: 11(B) (0x96)
            Supported Rates: 1(B) (0x82)
            Supported Rates: 2(B) (0x84)
            Supported Rates: 6 (0x0c)
            Supported Rates: 12 (0x18)
            Supported Rates: 24 (0x30)
            Supported Rates: 48 (0x60)
        Tag: DS Parameter set: Current Channel: 1
            Tag Number: DS Parameter set (3)
            Tag length: 1
            Current Channel: 1
        Tag: Traffic Indication Map (TIM): DTIM 0 of 0 bitmap
            Tag Number: Traffic Indication Map (TIM) (5)
            Tag length: 6
            DTIM count: 0
            DTIM period: 2
            Bitmap control: 0x00
                .... ...0 = Multicast: False
                0000 000. = Bitmap Offset: 0x00
            Partial Virtual Bitmap: 000000
        Tag: Country Information: Country Code CN, Environment Any
            Tag Number: Country Information (7)
            Tag length: 6
            Code: CN
            Environment: Any (0x20)
            Country Info: First Channel Number: 1, Number of Channels: 13, Maximum Transmit Power Level: 20 dBm
                Maximum Transmit Power Level (in dBm): 20
        Tag: ERP Information
            Tag Number: ERP Information (42)
            Tag length: 1
            ERP Information: 0x00
                .... ...0 = Non ERP Present: Not set
                .... ..0. = Use Protection: Not set
                .... .0.. = Barker Preamble Mode: Not set
                0000 0... = Reserved: 0x00
        Tag: Extended Supported Rates 54, 9, 18, 36, [Mbit/sec]
            Tag Number: Extended Supported Rates (50)
            Tag length: 4
            Extended Supported Rates: 54 (0x6c)
            Extended Supported Rates: 9 (0x12)
            Extended Supported Rates: 18 (0x24)
            Extended Supported Rates: 36 (0x48)
        Tag: RSN Information
            Tag Number: RSN Information (48)
            Tag length: 24
            RSN Version: 1
            Group Cipher Suite: 00-0f-ac TKIP
                Group Cipher Suite OUI: 00-0f-ac
                Group Cipher Suite type: TKIP (2)
            Pairwise Cipher Suite Count: 2
            Pairwise Cipher Suite List 00-0f-ac AES (CCM) 00-0f-ac TKIP
                Pairwise Cipher Suite: 00-0f-ac AES (CCM)
                    Pairwise Cipher Suite OUI: 00-0f-ac
                    Pairwise Cipher Suite type: AES (CCM) (4)
                Pairwise Cipher Suite: 00-0f-ac TKIP
                    Pairwise Cipher Suite type: TKIP (2)
            Auth Key Management (AKM) Suite Count: 1
            Auth Key Management (AKM) List 00-0f-ac PSK
                Auth Key Management (AKM) Suite: 00-0f-ac PSK
                    Auth Key Management (AKM) OUI: 00-0f-ac
                    Auth Key Management (AKM) type: PSK (2)
            RSN Capabilities: 0x0000
                .... .... .... ...0 = RSN Pre-Auth capabilities: Transmitter does not support pre-authentication
                .... .... .... ..0. = RSN No Pairwise capabilities: Transmitter can support WEP default key 0 simultaneously with Pairwise key
                .... .... .... 00.. = RSN PTKSA Replay Counter capabilities: 1 replay counter per PTKSA/GTKSA/STAKeySA (0x0000)
                .... .... ..00 .... = RSN GTKSA Replay Counter capabilities: 1 replay counter per PTKSA/GTKSA/STAKeySA (0x0000)
                .... .... .0.. .... = Management Frame Protection Required: False
                .... .... 0... .... = Management Frame Protection Capable: False
                .... ...0 .... .... = Joint Multi-band RSNA: False
                .... ..0. .... .... = PeerKey Enabled: False
        Tag: Vendor Specific: 00:50:f2: WPA Information Element
            Tag Number: Vendor Specific (221)
            Tag length: 26
            OUI: 00-50-f2
            Vendor Specific OUI Type: 1
            Type: WPA Information Element (0x01)
            WPA Version: 1
            Multicast Cipher Suite: 00-50-f2 TKIP
                Multicast Cipher Suite OUI: 00-50-f2
                Multicast Cipher Suite type: TKIP (2)
            Unicast Cipher Suite Count: 2
            Unicast Cipher Suite List 00-50-f2 AES (CCM) 00-50-f2 TKIP
                Unicast Cipher Suite: 00-50-f2 AES (CCM)
                    Unicast Cipher Suite OUI: 00-50-f2
                    Unicast Cipher Suite type: AES (CCM) (4)
                Unicast Cipher Suite: 00-50-f2 TKIP
                    Unicast Cipher Suite type: TKIP (2)
            Auth Key Management (AKM) List 00-50-f2 PSK
                Auth Key Management (AKM) Suite: 00-50-f2 PSK
                    Auth Key Management (AKM) OUI: 00-50-f2
        Tag: HT Capabilities (802.11n D1.10)
            Tag Number: HT Capabilities (802.11n D1.10) (45)
            Tag length: 26
            HT Capabilities Info: 0x116e
                .... .... .... ...0 = HT LDPC coding capability: Transmitter does not support receiving LDPC coded packets
                .... .... .... ..1. = HT Support channel width: Transmitter supports 20MHz and 40MHz operation
                .... .... .... 11.. = HT SM Power Save: SM Power Save disabled (0x0003)
                .... .... ...0 .... = HT Green Field: Transmitter is not able to receive PPDUs with Green Field (GF) preamble
                .... .... ..1. .... = HT Short GI for 20MHz: Supported
                .... .... .1.. .... = HT Short GI for 40MHz: Supported
                .... .... 0... .... = HT Tx STBC: Not supported
                .... ..01 .... .... = HT Rx STBC: Rx support of one spatial stream (0x0001)
                .... .0.. .... .... = HT Delayed Block ACK: Transmitter does not support HT-Delayed BlockAck
                .... 0... .... .... = HT Max A-MSDU length: 3839 bytes
                ...1 .... .... .... = HT DSSS/CCK mode in 40MHz: Will/Can use DSSS/CCK in 40 MHz
                ..0. .... .... .... = HT PSMP Support: Won't/Can't support PSMP operation
                .0.. .... .... .... = HT Forty MHz Intolerant: Use of 40 MHz transmissions unrestricted/allowed
                0... .... .... .... = HT L-SIG TXOP Protection support: Not supported
            A-MPDU Parameters: 0x00
                .... ..00 = Maximum Rx A-MPDU Length: 0x00 (8191[Bytes])
                ...0 00.. = MPDU Density: no restriction (0x00)
                000. .... = Reserved: 0x00
            Rx Supported Modulation and Coding Scheme Set: MCS Set
                Rx Modulation and Coding Scheme (One bit per modulation): 1 spatial stream
                    .... .... .... .... .... .... 1111 1111 = Rx Bitmask Bits 0-7: 0x000000ff
                    .... .... .... .... 0000 0000 .... .... = Rx Bitmask Bits 8-15: 0x00000000
                    .... .... 0000 0000 .... .... .... .... = Rx Bitmask Bits 16-23: 0x00000000
                    0000 0000 .... .... .... .... .... .... = Rx Bitmask Bits 24-31: 0x00000000
                    .... .... .... .... .... .... .... ...0 = Rx Bitmask Bit 32: 0x00000000
                    .... .... .... .... .... .... .000 000. = Rx Bitmask Bits 33-38: 0x00000000
                    .... .... ...0 0000 0000 0000 0... .... = Rx Bitmask Bits 39-52: 0x00000000
                    ...0 0000 0000 0000 0000 0000 000. .... = Rx Bitmask Bits 53-76: 0x00000000
                .... ..00 0000 0000 = Highest Supported Data Rate: 0x0000
                .... .... .... ...1 = Tx Supported MCS Set: Defined
                .... .... .... ..0. = Tx and Rx MCS Set: Equal
                .... .... .... 00.. = Maximum Number of Tx Spatial Streams Supported: 0x0000, 1 spatial stream
                .... .... ...0 .... = Unequal Modulation: Not supported
            HT Extended Capabilities: 0x0000
                .... .... .... ...0 = Transmitter supports PCO: Not supported
                .... .... .... .00. = Time needed to transition between 20MHz and 40MHz: No Transition (0x0000)
                .... ..00 .... .... = MCS Feedback capability: STA does not provide MCS feedback (0x0000)
                .... .0.. .... .... = High Throughput: Not supported
                .... 0... .... .... = Reverse Direction Responder: Not supported
            Transmit Beam Forming (TxBF) Capabilities: 0x00000000
                .... .... .... .... .... .... .... ...0 = Transmit Beamforming: Not supported
                .... .... .... .... .... .... .... ..0. = Receive Staggered Sounding: Not supported
                .... .... .... .... .... .... .... .0.. = Transmit Staggered Sounding: Not supported
                .... .... .... .... .... .... .... 0... = Receive Null Data packet (NDP): Not supported
                .... .... .... .... .... .... ...0 .... = Transmit Null Data packet (NDP): Not supported
                .... .... .... .... .... .... ..0. .... = Implicit TxBF capable: Not supported
                .... .... .... .... .... .... 00.. .... = Calibration: incapable (0x00000000)
                .... .... .... .... .... ...0 .... .... = STA can apply TxBF using CSI explicit feedback: Not supported
                .... .... .... .... .... ..0. .... .... = STA can apply TxBF using uncompressed beamforming feedback matrix: Not supported
                .... .... .... .... .... .0.. .... .... = STA can apply TxBF using compressed beamforming feedback matrix: Not supported
                .... .... .... .... ...0 0... .... .... = Receiver can return explicit CSI feedback: not supported (0x00000000)
                .... .... .... .... .00. .... .... .... = Receiver can return explicit uncompressed Beamforming Feedback Matrix: not supported (0x00000000)
                .... .... .... ...0 0... .... .... .... = STA can compress and use compressed Beamforming Feedback Matrix: not supported (0x00000000)
                .... .... .... .00. .... .... .... .... = Minimal grouping used for explicit feedback reports: No grouping supported (0x00000000)
                .... .... ...0 0... .... .... .... .... = Max antennae STA can support when CSI feedback required: 1 TX antenna sounding (0x00000000)
                .... .... .00. .... .... .... .... .... = Max antennae STA can support when uncompressed Beamforming feedback required: 1 TX antenna sounding (0x00000000)
                .... ...0 0... .... .... .... .... .... = Max antennae STA can support when compressed Beamforming feedback required: 1 TX antenna sounding (0x00000000)
                .... .00. .... .... .... .... .... .... = Maximum number of rows of CSI explicit feedback: 1 row of CSI (0x00000000)
                ...0 0... .... .... .... .... .... .... = Maximum number of space time streams for which channel dimensions can be simultaneously estimated: 1 space time stream (0x00000000)
                000. .... .... .... .... .... .... .... = Reserved: 0x00000000
            Antenna Selection (ASEL) Capabilities: 0x00
                .... ...0 = Antenna Selection Capable: Not supported
                .... ..0. = Explicit CSI Feedback Based Tx ASEL: Not supported
                .... .0.. = Antenna Indices Feedback Based Tx ASEL: Not supported
                .... 0... = Explicit CSI Feedback: Not supported
                ...0 .... = Antenna Indices Feedback: Not supported
                ..0. .... = Rx ASEL: Not supported
                .0.. .... = Tx Sounding PPDUs: Not supported
                0... .... = Reserved: 0x00
        Tag: HT Information (802.11n D1.10)
            Tag Number: HT Information (802.11n D1.10) (61)
            Tag length: 22
            Primary Channel: 1
            HT Information Subset (1 of 3): 0x05
                .... ..01 = Secondary channel offset: Secondary channel is above the primary channel (0x01)
                .... .1.. = Supported channel width: Channel of any width supported
                .... 0... = Reduced Interframe Spacing (RIFS): Prohibited
                ...0 .... = Power Save Multi-Poll (PSMP) stations only: Association requests are accepted regardless of PSMP capability
                000. .... = Shortest service interval: 5 ms (0x00)
            HT Information Subset (2 of 3): 0x0000
                .... .... .... ..00 = Operating mode of BSS: All STAs are - 20/40 MHz HT or in a 20/40 MHz BSS or are 20 MHz HT in a 20 MHz BSS (0x0000)
                .... .... .... .0.. = Non-greenfield STAs present: All associated STAs are greenfield capable
                .... .... .... 0... = Transmit burst limit: No limit
                .... .... ...0 .... = OBSS non-HT STAs present: Use of protection for non-HT STAs by overlapping BSSs is not needed
                0000 0000 000. .... = Reserved: 0x0000
            HT Information Subset (3 of 3): 0x0000
                .... .... ..00 0000 = Reserved: 0x0000
                .... .... .0.. .... = Dual beacon: No second beacon is transmitted
                .... .... 0... .... = Dual Clear To Send (CTS) protection: Not required
                .... ...0 .... .... = Beacon ID: Primary beacon
                .... ..0. .... .... = L-SIG TXOP Protection Full Support: One or more HT STAs in the BSS do not support L-SIG TXOP protection
                .... .0.. .... .... = Phased Coexistence Operation (PCO): Inactive
                .... 0... .... .... = Phased Coexistence Operation (PCO) Phase: Switch to or continue 20 MHz phase
                0000 .... .... .... = Reserved: 0x0000
            Rx Supported Modulation and Coding Scheme Set: Basic MCS Set
                Rx Modulation and Coding Scheme (One bit per modulation): Reserved:8
                    .... .... .... .... .... .... 0000 0000 = Rx Bitmask Bits 0-7: 0x00000000
                .... .... .... ...0 = Tx Supported MCS Set: Not defined
                .... .... .... 00.. = Maximum Number of Tx Spatial Streams Supported: 0x0000, TX MCS Set Not Defined
        Tag: Vendor Specific: 00:50:f2: WMM/WME: Parameter Element
            Tag length: 24
            OUI: 00-50-f2
            Vendor Specific OUI Type: 2
            Type: WMM/WME (0x02)
            WME Subtype: Parameter Element (1)
            WME Version: 1
            WME QoS Info: 0x04
                0... .... = U-APSD: Disabled
                .... 0100 = Parameter Set Count: 0x04
                .000 .... = Reserved: 0x00
            Reserved: 00
            Ac Parameters ACI 0 (Best Effort), ACM no, AIFSN 3, ECWmin 4, ECWmax 10, TXOP 0
                ACI / AIFSN Field: 0x03
                    .00. .... = ACI: Best Effort (0)
                    ...0 .... = Admission Control Mandatory: No
                    .... 0011 = AIFSN: 3
                ECW: 0xa4
                    1010 .... = ECW Max: 10
                    .... 0100 = ECW Min: 4
                TXOP Limit: 0
            Ac Parameters ACI 1 (Background), ACM no, AIFSN 7, ECWmin 4, ECWmax 10, TXOP 0
                ACI / AIFSN Field: 0x27
                    .01. .... = ACI: Background (1)
                    .... 0111 = AIFSN: 7
                ECW: 0xa4
                TXOP Limit: 0
            Ac Parameters ACI 2 (Video), ACM no, AIFSN 2, ECWmin 3, ECWmax 4, TXOP 94
                ACI / AIFSN Field: 0x42
                    .10. .... = ACI: Video (2)
                    .... 0010 = AIFSN: 2
                ECW: 0x43
                    0100 .... = ECW Max: 4
                    .... 0011 = ECW Min: 3
                TXOP Limit: 94
            Ac Parameters ACI 3 (Voice), ACM no, AIFSN 2, ECWmin 2, ECWmax 3, TXOP 47
                ACI / AIFSN Field: 0x62
                    .11. .... = ACI: Voice (3)
                ECW: 0x32
                    0011 .... = ECW Max: 3
                    .... 0010 = ECW Min: 2
                TXOP Limit: 47
        Tag: Vendor Specific: 50:6f:9a: P2P
            Tag length: 45
            OUI: 50-6f-9a
            Vendor Specific OUI Type: 9
            P2P Capability: Device 0x25  Group 0x0
                Attribute Type: P2P Capability (2)
                Attribute Length: 2
                Device Capability Bitmap: 0x25
                .... ...1 = Service Discovery: 0x01
                .... ..0. = P2P Client Discoverability: 0x00
                .... .1.. = Concurrent Operation: 0x01
                .... 0... = P2P Infrastructure Managed: 0x00
                ...0 .... = P2P Device Limit: 0x00
                ..1. .... = P2P Invitation Procedure: 0x01
                Group Capability Bitmap: 0x00
                .... ...0 = P2P Group Owner: 0x00
                .... ..0. = Persistent P2P Group: 0x00
                .... .0.. = P2P Group Limit: 0x00
                .... 0... = Intra-BSS Distribution: 0x00
                ...0 .... = Cross Connection: 0x00
                ..0. .... = Persistent Reconnect: 0x00
                .0.. .... = Group Formation: 0x00
            P2P Device Info
                Attribute Type: P2P Device Info (13)
                Attribute Length: 33
                P2P Device address: 94:b9:7e:6b:70:69
                Config Methods: 0x0188
                .... .... .... ...0 = USBA (Flash Drive): 0x0000
                .... .... .... ..0. = Ethernet: 0x0000
                .... .... .... .0.. = Label: 0x0000
                .... .... .... 1... = Display: 0x0001
                .... .... ...0 .... = External NFC Token: 0x0000
                .... .... ..0. .... = Integrated NFC Token: 0x0000
                .... .... .0.. .... = NFC Interface: 0x0000
                .... .... 1... .... = PushButton: 0x0001
                .... ...1 .... .... = Keypad: 0x0001
                Primary Device Type: 00060050f2040001
                Primary Device Type: Category: 6
                Primary Device Type: OUI: 0050f204
                Primary Device Type: Subcategory: 1
                Number of Secondary Device Types: 0
                Device Name attribute type: 0x1011
                Device Name attribute length: 12
                Device Name: amba-07aa9a9
faidon
Postby faidon » Sat May 31, 2025 4:32 pm
I have the same question. Can someone knowledgeable enough answer please?
Also does anyone know how esp-now works under the hood? I assume it does something similar, so we should be able to replicate this behaviour of custom frames.
Thanks!
MicroController
Postby MicroController » Sat May 31, 2025 8:45 pm
Users browsing this forum: Bing [Bot], meta-externalagent and 3 guests
