Library for compression algorithm
Saskia
Postby Saskia » Mon Jun 26, 2017 11:47 am
is there a library for compression algorithm? I want to use huffman (or any other) kind of algorithm to compress my data.
I have a lot of hex values like
49 00 06 00 37 2A 00 01
20 DD 09 00 10 18 02 01
These values should be compressed, before storing them, so the file size is way less.
- Saskia
ESP_igrr
Re: Library for compression algorithm
Postby ESP_igrr » Mon Jun 26, 2017 11:59 am
ESP32 ROM code contains some functions from miniz compression library: rom/miniz.h.
Miniz has a number of APIs, but the ones which are available in the ROM are the low-level tdefl_*/tinfl_* compression and decompression functions.
loboris
Postby loboris » Mon Jun 26, 2017 12:46 pm
You can use zlib library (https://github.com/madler/zlib).
Copy only the *.c & *.h files from root directory. I't compiles without problems.
You can find an example in https://github.com/loboris/ESP32_curl_example, components/zlib directory.
Saskia
Postby Saskia » Mon Jun 26, 2017 4:54 pm
thanks. I will try the zlib library.
- Saskia
snahmad75
Postby snahmad75 » Tue Jun 19, 2018 1:06 pm
https://github.com/madler/zlib is not building on esp32
Have any one manage to uncompress any zip format file include all sub folder into folder on esp32.
Thanks,
Naeem
jubueche
Postby jubueche » Thu Feb 07, 2019 3:56 pm
I had to add #include <unistd.h> to gzread and gzwrite. Also, I added #include <unistd.h> and #include <sys/types.h> to gzlib.c
It compiled afterwards. Don't forget to put header files in components/zlib/include and c files in components/zlib/
Users browsing this forum: No registered users and 22 guests
