how to proper shut down wifi then turn on and reconnect to wifi
NIXIE_123
Postby NIXIE_123 » Sat Aug 14, 2021 12:19 pm
Hello
What i want:
Connect to wifi
esp_wifi_stop()
Reconnect to wifi
esp_wifi_stop()
For now I only connect to wifi once
    if(ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND){
    ESP_ERROR_CHECK(ret);
    s_wifi_event_group = xEventGroupCreate();
    esp_netif_create_default_wifi_sta();
    ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL, &instance_any_id));
    ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler, NULL, &instance_got_ip));
   wifi_config_t wifi_config = {
    	           	 .sta = {
    	           	 .ssid = EXAMPLE_ESP_WIFI_SSID,
    	           	 .password = EXAMPLE_ESP_WIFI_PASS,
    	           	 .threshold.authmode = WIFI_AUTH_WPA2_PSK,
    	           	    .pmf_cfg = {
    	           	       .capable = true,
    	                   .required = false
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_wifi_start() );
    EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group, WIFI_CONNECTED_BIT | WIFI_FAIL_BIT, pdFALSE, pdFALSE, portMAX_DELAY);
    if (bits & WIFI_CONNECTED_BIT) {
        //sntp sync
    ESP_ERROR_CHECK(esp_wifi_stop() );
    vTaskDelay(3000/portTICK_PERIOD_MS);
             ESP_LOGI(TAG, "connected to ap SSID:%s password:%s", EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
        } else if (bits & WIFI_FAIL_BIT) {
             ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s", EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
             ESP_LOGE(TAG, "UNEXPECTED EVENT");
    if(bits & WIFI_CONNECTED_BIT){
    	//sntp sync
What I am doing wrong?
NIXIE_123
Re: how to proper shut down wifi then turn on and reconnect to wifi
Postby NIXIE_123 » Sat Aug 14, 2021 4:19 pm
solution:
    	           	 .sta = {
    	           	    .pmf_cfg = {
    	           	       .capable = true,
    	                   .required = false
        //sntp sync
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
    vEventGroupDelete(s_wifi_event_group);
    	//sntp sync
Users browsing this forum: Baidu [Spider], meta-externalagent, PerplexityBot and 3 guests
