External Flash Logging Issue
Posted: Mon Aug 16, 2021 9:39 pm
Hello all,
I have stumbled upon an issue in which I am logging to a filesystem and randomly during some flash writes the ESP32 will freeze all tasks and trip the watchdog for the task which is writing to the ESP32-Wrover's flash chip. I am just curious as to if this is a known issue or not?
I've implemented littlefs as the filesystem and utilize the api as the writing writing functionality of the filesystem.
I have tried using the vfs with SPIFFS as well and have run into this issue as well.
The current implementation is, I have a circular buffer that holds a certain amount of data and a task serving log writes, the log writes 512 byte chunks at a time to flash. Randomly, the api freezes and trips the watchdog.
Is this logging scheme not possible due to running this on the same flash chip that we are executing in place from?
Please let me know!
Task watchdog is currently set at 15 seconds.
esp_partition_writeI have tried using the vfs with SPIFFS as well and have run into this issue as well.
esp_partition_writeIs this logging scheme not possible due to running this on the same flash chip that we are executing in place from?
Please let me know!
