TTGO ESP32 not connecting
MellBesp
Postby MellBesp » Thu Sep 02, 2021 11:08 am
so i have a "TTGO Lora32-Oled V1" board. It was working fine yesterday and now I get this output, when I try to upload anything
esptool.py v3.0-dev
Serial port /dev/ttyUSB0
Connecting........_____....._____....._____....._____....._____....._____....._____
I tried all the boot, rst pin options. But then looking at the serial monitor I don't see anything. So no "waiting for download" nothing.
I tried connecting GND to GPIO0, still nothing.
The serial connection is there though, since if I write
ls /dev/tty*
in my terminal. I find USB0 only than the board is connected.
I have another board here and this one flashes fine.
So I guess my board is broken or not? What I don't get is how it was working fine yesterday and now it doesn't anymore I didn't change my circuit.
Interestingly when I started my circuit today I didn't get any serial output from the esp32, so it must have broken at some point. I'm kind of worried I'm gonna break another one.
I either power it through my laptop or through a Teensy 3.6, the connections are:
ESP32<-> Teesny3.6
GND <-> GND
3.3V <-> Vin
GPIO23 <-> GPIO7
GPIO13 <-> GPIO8
I would really appreciate some help.
Re: TTGO ESP32 not connecting
Postby Sprite » Fri Sep 03, 2021 2:18 am
Only issue is that Vin is generally used for e.g. 5V input; 3.3V is technically too low for it, and depending on the board, it may actually have fed 5V back into your Teensy if you had USB connected. That shouldn't be able to damage the ESP32 board, though.
MellBesp
Postby MellBesp » Fri Sep 03, 2021 9:22 am
So if I would connect my Teensy to the 5V it wouldn't break my board?
