ESP32-S3 dual-mode Bluetooth 5.0 (BR/EDR + BLE)
Hello, we have heard about the upcoming ESP32-S3 device on Espressif website and it states that it supports WiFi + BLE 5.0, but there is no data sheet. Can anyone please confirm whether it supports a dual-mode Bluetooth 5.0 (BR/EDR + BLE) or not. Because our application is related to WiFi + Bluetooth audio streaming including BLE which is supported by a baseline ESP32 device.
Thanks in advance.
Thanks in advance.
Re: ESP32-S3 dual-mode Bluetooth 5.0 (BR/EDR + BLE)
Does anyone know the answer to this question? Could any of Espressif's technician please clarify us with the ESP32-S3 dual mode bluetooth 5.0?
Waiting for your kind.
Rivers.
Rivers.
BR/EDR is Bluetooth Classic, right? If so, no; the S3 only supports BLE. The datasheet for the S3 will (re-)appear on our website around the end of this month if you need more info.
ESP_Sprite, thanks for your confirmation.
But it make us a little bit disappointed regarding a missing of dual-mode Bluetooth BR/EDR + BLE 5.0. Since we've seen the demonstration of single chip ESP32-S3 based smart speaker on the Espressif's YouTube channel without the need for dedicated audio DSP chip. It could process all required stuffs like noise reduction, beam forming and acoustic echo cancellation (AEC) on its own for local wake words voice recognition.
So the missing of Bluetooth classic mode BR/EDR will force the devices to rely only on indoor WiFi router for audio applications and render the mobile phone's Bluetooth based audio streaming application useless and this is required for outdoor use case scenarios, as seen in a car or on the street.
We really hope Espressif will reconsider add this functionality on its ESP32-S3 firmware or may be on a very next ESP32-S variants, unless we have to stick with an old solutions ESP32 + Audio DSP which are significantly higher cost.
Thanks you & best regard.
Rivers.
Rivers.
You can always use S3 + old esp32, which is not that much expensive.unless we have to stick with an old solutions ESP32 + Audio DSP which are significantly higher cost.
Thanks for your idea. Yes that's probably a workaround for hobbyist. But you will end up with 4 cores MCU @ 160MHz along with 2 SPI Flash memories draining lot of power, let alone managing 2 OS through OTA update.You can always use S3 + old esp32, which is not that much expensive.unless we have to stick with an old solutions ESP32 + Audio DSP which are significantly higher cost.
In commercial application only single core Cortex M7 @ 480MHz with DSP instructions combine with Murata WiFi + dual-mode BLE chip and 1 SPI Flash could do the same job, but it won't be able to beat the ESP32-S3 (if the dual-mode BLE still retain) in term of price and power consumption.
Best regard.
Rivers.
As you maybe know there is esp32 SOLO with just 1 core (and maybe embedded flash). Bluetooth is also able to work with MCU @ 80MHz and with 32kHz crystal there is power safe mode.Thanks for your idea. Yes that's probably a workaround for hobbyist. But you will end up with 4 cores MCU @ 160MHz along with 2 SPI Flash memories draining lot of power,
Sure, maintaining 2 firmware is drawback, but espressif is providing AT command firmware to control bluetooth.
I can see reasons why BT classic may be not existing on S3:
- hardware complexity and production cost,
- firmware and RAM consumption,
- probably more i cant image from top of my head
Im not saying your questions or needs are not important, just saying what you can do to stick to esp32 and keep product cost low.
off topic:
As small off topic i would like to say that espressif could make in future dev kits even cheaper if they use esp32 S2 instead of CP210X thanks to native USB, maybe even with preinstalled binary with option to flash main chip from web browser without implementing it in user app
off topic:
Hi chegewara,
I will try to elaborate and educate you as much as I can from the RF engineer and the company's point of view in order to prevent others from trying to experiment with your risky proposal.
We are a company and in order to retain competitiveness, the company usually makes products based on existing approved reference designs. They buy IP cores, Source code licenses, etc.. and top up each other with their in-house development to make the products. They do not go into a time-consuming "reinvent the wheel" route that poses many risks. And I'm talking about "Real World Scenarios" as well as in "Commercial off the shelf Products". Have you ever seen company stitches 2 WiFi MCUs together in close proximity?
Your proposal is a "reinvent the wheel" route that has no approved reference implementation (If you have a reference design of your own, you give me the link, FCC approved preferred). If you would like to know more about an RF-approved reference design it'd be better to check out this link (https://developer.amazon.com/en-US/alex ... s/dev-kits).
No matter there are workarounds using AT commands or migrate to a single core MCU in low power mode. Your proposal of stitching 2 WiFi MCUs together in close proximity will exhibit a risk, and I believe that an Espressif's engineer, as well as all RF engineers, will never recommend doing that at all, due to the RF regulation issues. Because chances are that software/hardware malfunction or even a hacker could lead to accidentally turn on both radios simultaneously, thus violates the RF regulations. This is the answer to your off-topic question regarding why Espressif's engineer will never replace CP210X with S2 for sure.
If you have ever designed a Linux-based WiFi router like us or at least look inside it, you will notice that there are only a single Linux-based WiFi "CPU" (multi-cores if need) couples with multi-band RF AFE ICs and there are a mechanism called packet traffic arbitration (PTA) implemented in the hardware of each RF AFE ICs in order to chop transmitting time frames share among each RF ICs this is required for the coexistence RF like multi-transmitters WiFi and WiFi + Bluetooth which operates on the same RF band.
The ESP32 itself (literally most of WiFi "MCU") doesn't have a mechanism to synchronize through IEEE 802.15.2 packet traffic arbitration (PTA) between each WiFi and Bluetooth transmitter, see this post (viewtopic.php?f=12&t=8527&sid=ecbdd8f25 ... f22103a393). That's why your approach doesn't exist in real life.
Moreover, it will eventually have to get approved by part 15 of FCC rules which is very costly if you put 2 "Intentional Radiators" on the same frequency band in very close proximity (less than 20 cm) which costs you at least $5000 per radiator. Yes, you can utilize a modular approval of ESP32 RF modules in your design then turn on only ESP32 radios and shut down the S3 radios, but the FCC doesn't care as long as both chipsets are capable of transmitting RF power. They will treat your design falls into "FCC Multi-transmitters/Antennas Co-location" categories then double or triple the certification fees and hence the pre-certified house doesn't help much due to the complexity of the RF radiation pattern. These are the dead-load costs that make products more expensive. Your approach will never get cheap at all.
Espressif is also a company and they make products based on the market demand, so if the demand is high enough I see no reason why they should not make a dual-mode BLE ESP32-Sx series or even a dual-band WiFi 2.4/5GHz variant, check this out $6 module from Realtek (https://www.cnx-software.com/2021/01/10 ... eless-mcu/). Since they have already obtained the licenses of RISC-V and LX7 along with its own in-house WiFi/Bluetooth RF subsystems. To answer your question regarding how hard to produce such a chip. If you have ever learned VLSI design before, the production cost is not as high as you guess, because they utilize a TSMC high yield maturity 40nm ULP process, the same process used to manufacture low-cost Cortex M0-M7 variants, and the production cost of the chip at this 40nm scale always depends on the "die size" and "royalty fees of IP cores" rather than the complexity of the chip itself.
So it is only the question of when they will announce to the public.
Finally, I'm not talking about cheap design. Instead, I'm talking about a lower price than the existing design. If I were you I would rather recommend Kendryte K210 + ESP32 for this kind of application instead, since its CNN @ 0.5 TOPS is more powerful than the S3 at the same price point and it also has a Tensorflow workspace for K210. But as I said earlier managing 2 OS through OTA update is a tradeoff.
So I would like to get information directly from Espressif's technician for sure when available rather than personal opinions.
Thanks for your corporation.
Rivers
HiBR/EDR is Bluetooth Classic, right? If so, no; the S3 only supports BLE. The datasheet for the S3 will (re-)appear on our website around the end of this month if you need more info.
I'm confused ! every Bluetooth Documents that I read said: every chip or module or ... that work with BLE will Support Bluetooth Classic(BR/EDR).
you sure S3 doesn't support it?
and I did not study ESP32 C3 datasheet so you mean is it too ??
Yes. The only chip we have at this moment which does BT Classic is the (non-C, non-S, original) ESP32.
Users browsing this forum: Bing [Bot], Bytespider, Qwantbot and 2 guests
