ESP32-C3-DEVKIT-1 schematic
jonsmirl
Postby jonsmirl » Tue Sep 07, 2021 2:15 am
https://dl.espressif.com/dl/schematics/ ... 00915A.pdf
Is the RGB LED really running on 3.3V? The datasheet for SK68XXMINI-HS says 3.7V minimum.
https://www.rose-lighting.com/wp-conten ... -thick.pdf
Maybe it is hooked to 5V and the schematic is wrong? Or does this RGB LED really work on 3.3V?
Re: ESP32-C3-DEVKIT-1 schematic
Postby Sprite » Tue Sep 07, 2021 12:20 pm
I'll see if I can double-check, but yeah, it looks like that. From what I recall, it mostly affects the color purity (as the blue and green die can be underpowered) but aside from that doesn't really affect the functionality of the device... and as it's simply used as an indicator here, color purity isn't that important.
bobolink
Postby bobolink » Wed Sep 08, 2021 2:09 pm
On a ESP32-C3-DevKitM-1 I measured 3.29 VDC
White looks a little blueish but they all do for me Edit: (all white LEDs look a little blue for me).
