VSCode ESP-IDF Flash and Ram Size
mm_1993
Postby mm_1993 » Mon Sep 13, 2021 10:27 am
Hi
I test esp32 idf with PlatformIO
one interesting thing on it that was after compiling we can see this :
RAM: [=........] 9.9% (used 32516 bytes from 327680 bytes)
Flash: [========....] 77.7% (used 814548 bytes from 1048576 bytes)
I hope vscode esp-idf extension support it too
it make easy way to show and understand :)
thank you.
kondalkolipaka
Re: VSCode ESP-IDF Flash and Ram Size
Postby kondalkolipaka » Mon Sep 13, 2021 1:21 pm
I think it's a useful feature. For now, you should be able to see flash and RAM usage using the "Size analysis of the binaries" command
https://github.com/espressif/vscode-esp ... e-commands
mm_1993
Postby mm_1993 » Wed Sep 15, 2021 11:05 am
thank you @kondalkolipaka
it's look good
mriksman
Postby mriksman » Wed Jan 19, 2022 11:37 am
@ESP_kondalkolipaka
I'd like this to show TOTAL bin size vs PARTITION sizes available. It'd be nice to see how much space the bin file is compared to what partitions are available.
Time-is-life
Postby Time-is-life » Tue Feb 01, 2022 4:03 am
Here's what the Build command in VSCode ESP-IDF extension v1.3
reports using ESP-IDF v4.4
