ESP32-LyraTD-MSC alexa识别问题
wulin198550
Postby wulin198550 » Fri Sep 17, 2021 12:28 pm
开发板:ESP32-LyraTD-MSC
IDF:v3.2.5-1-g110d230e36-dirty
ESP-va-sdk:github上master分支版本
已经跑起来,并通过ESP Alexa android客户端配好上网,但是川口一直提示有问题,语音也无法唤醒(Alexa和hi lexin都有试过)。错误日至如下(请教是什么问题):
W (597323) LSSDP: received unknown SSDP packet
W (597333) LSSDP: received unknown SSDP packet
W (597343) LSSDP: received unknown SSDP packet
W (597353) LSSDP: received unknown SSDP packet
W (597363) LSSDP: received unknown SSDP packet
W (598963) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (598963) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (599163) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (599163) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (604283) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (604283) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (609613) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (609613) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (609813) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (609813) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (614933) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (614933) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
[http_stream]: [stream_new]: Internal: 52840, External: 1278276
[http_stream]: [stream_get: 21]: /ping
[http_stream]: [sid: 21] Response code: 204
[615 seconds]: [http_stream]: [stream_delete: 21] Internal: 52560, External: 1278064, min ever internal: 37140, largest free block: 42348
W (617593) LSSDP: received unknown SSDP packet
W (617603) LSSDP: received unknown SSDP packet
W (617613) LSSDP: received unknown SSDP packet
W (617623) LSSDP: received unknown SSDP packet
W (617633) LSSDP: received unknown SSDP packet
W (620263) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (620263) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (620463) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (620463) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (625583) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (625583) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (625783) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (625783) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (630913) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (630913) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (631113) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (631113) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (636233) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (636233) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (637873) LSSDP: received unknown SSDP packet
W (637883) LSSDP: received unknown SSDP packet
W (637893) LSSDP: received unknown SSDP packet
W (637903) LSSDP: received unknown SSDP packet
W (637913) LSSDP: received unknown SSDP packet
W (641563) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (641563) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (641763) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (641763) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (646883) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (646883) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (650563) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (650563) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (652203) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (652213) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (652413) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (652413) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (657533) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (657533) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (658353) LSSDP: received unknown SSDP packet
W (658363) LSSDP: received unknown SSDP packet
W (658373) LSSDP: received unknown SSDP packet
W (658383) LSSDP: received unknown SSDP packet
W (658393) LSSDP: received unknown SSDP packet
W (662863) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (662863) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
W (663063) httpd_uri: httpd_uri: URI '/rootDesc.xml' not found
W (663063) httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist
Code: Untitled.c Select all
wulin198550
Re: ESP32-LyraTD-MSC alexa识别问题
Postby wulin198550 » Sat Sep 18, 2021 8:16 am
问题已解决。就是网络不通
HengYC
Postby HengYC » Tue Oct 12, 2021 11:39 am
你好,
log 提示 httpd_txrx: httpd_resp_send_err: 404 Not Found - This URI doesn't exist 应该是网络问题。
Users browsing this forum: YisouSpider and 1 guest
