I was trying to design an ESP32-WROOM-32U board which would drive a very low power motor with a MOSFET, and used a regular AMS1117 to power the whole thing. The board was fully assembled at JLCPCB.
I am not getting any messages through serial from the board, not from the CP2102 nor from a USB to UART adapter I plugged in to the TX and RX pins.
I tried various ON/OFF combinations of EN and IO0, to no success. The ESP32 will simply not send anything through serial, so I can't check if it is functioning, even less upload stuff to it. I will upload the datasheet and the Gerber in case anyone wants to take a look.
Thank you all for you help, hopefully it is simply a missing component or some dumb beginner mistake.
Gerber: https://drive.google.com/file/d/1WOD-zZ ... sp=sharing
