Page 1 of 2
USB Host
Posted: Thu Sep 23, 2021 11:07 am
by Unique
Code: Untitled.c Select all
使用USBh_cdc库时遇到如下问题:
[0;32mI (00:00:23.598) USB_HCDC: Resetting Port
[0m
[0;32mI (00:00:23.658) USB_HCDC: Port speed = 1
[0m
[0;32mI (00:00:23.661) USB_HCDC: Pipe Default Created[0m
[0;32mI (00:00:23.663) USB_HCDC: 1. Set Device Addr = 1[0m
[0;33mW (00:00:23.666) USB_HCDC: line 393 Pipe: default HCD_PIPE_EVENT_ERROR_XFER[0m
USB配置部分代码
void peripherals_usb_config(void)
static const char *TAG = "USB_configuration";
usb_ep_desc_t bulk_out_ep_desc =
.bLength = sizeof(usb_ep_desc_t),
.bDescriptorType = USB_B_DESCRIPTOR_TYPE_ENDPOINT,
.bEndpointAddress = 0x0f, //endpiont f
.bmAttributes = USB_BM_ATTRIBUTES_XFER_BULK,
.wMaxPacketSize = 64, //MPS of 64 bytes
.bInterval = 0,
usb_ep_desc_t bulk_in_ep_desc =
.bEndpointAddress = 0x86, //endpoint 6
.bInterval = 0,
usbh_cdc_config_t usbh_cdc_configuration =
.bulk_in_ep = &bulk_in_ep_desc,
.bulk_out_ep = &bulk_out_ep_desc,
.rx_buffer_size = 1024,
.tx_buffer_size = 1024,
.rx_callback = usb_event_cd,
esp_err_t ret = usbh_cdc_driver_install(&usbh_cdc_configuration);
assert(ret == ESP_OK);
xTaskCreate(usb_task,"usb_task",4096,NULL,2,NULL);
ESP_LOGI(TAG,"ret:%d",ret);
Re: USB Host
Posted: Fri Sep 24, 2021 9:35 pm
by chegewara
Re: USB Host
Posted: Sat Sep 25, 2021 1:01 am
by Unique
配置过程和例程是一样的,只是修改了端点地址和接收缓冲区大小。
出现default HCD_PIPE_EVENT_ERROR_XFER的原因一般有哪些呢?
另外,
Re: USB Host
Posted: Sat Sep 25, 2021 1:24 am
by Unique
您好,我使用的是移远的EC200N-CN配置过程和您提供的例程是一样的,只是修改了端点地址。另外,当我配置完成后将4G模块关机时,USB会提示连接已断开,这应该能说明USB连接时正常的。
但是没法正常通信,并且会有pipe的报错,这个报错通常跟哪些因素有关呢?
Re: USB Host
Posted: Sun Sep 26, 2021 12:55 am
by Unique
问题解决了,是外围USB线上多焊了一个预留的电容。
另外我想请教一下,S2 USB线上的15K下拉电阻以及USB device端标识速率的1.5K上拉电阻是否必要?
Re: USB Host
Posted: Sun Sep 26, 2021 3:51 am
by Bob
USB 会根据所选的速率模式,自动配置内部上拉,没有必要再外部配置上拉电阻。ESP32-S2/S3 USB D+, D- 直接与设备 USB 接口相连即可。
Re: USB Host
Posted: Sun Sep 26, 2021 5:56 am
by Unique
您好,当我在使用过程中将4G模块关机后,usb会提示disconnect ,再将4g模块开机,这时USB无法通信。这种情况下是需要
1、usbh_cdc_driver_delete后再重新usbh_cdc_driver_install,
还是直接
2、usbh_cdc_driver_install呢?
两种方法我都试了一下,采用第一种方式,会在
while (xEventGroupGetBits(s_usb_event_group) & (USB_TASK_PIPES_KILL_BITS | PORT_TASK_KILL_BIT)) {
ESP_LOGW(TAG, "Waitting for USB Driver uninstall");
vTaskDelay(50 / portTICK_PERIOD_MS);
中一直循环。
采用第二种方式会提示
if (usb_driver_is_init()) {
ESP_LOGW(TAG, "USB Driver has inited");
return ESP_ERR_INVALID_STATE;
而后依然无法通信
Re: USB Host
Posted: Mon Sep 27, 2021 11:51 am
by Bob
4G 模块关机以后 USB 通信将断开。由于当前 USB Host 协议栈还不完善,不支持热插拔等操作。如果重新开机,目前的建议是,通过 IO 控制 4G 模块开机以后,将 ESP32S2 直接 restart。
Re: USB Host
Posted: Tue Sep 28, 2021 12:51 am
by Unique
好的,感谢
Re: USB Host
Posted: Sat Oct 09, 2021 6:35 am
by Unique
有个问题再请教一下:
使用过程中,无法发送64byte数据,也就是wMaxPacketSize大小的数据,看网上STM32的解决方案是当数据长度正好为64Byte时,补发一包0字节的数据,告诉USB控制器数据已经发送完成了。但是我尝试过之后发现在ESP32 S2上不可行。
请问有其他的解决方案吗?
void network_lte_send(const void* src, size_t size)
  static const char *TAG = "USB输出";
  switch (LTE_trans_mode_default)
  case LTE_trans_usb:
    if(size == 64)
      ESP_LOGI(TAG,"64字节");
      usbh_cdc_write_bytes(src,size);
      usbh_cdc_write_bytes(NULL,0);
    else
    break;
  case LTE_trans_uart:
    uart_write_bytes(UART_NUM_0,src,size);
  default:
    break;
