How to compile BLE example code with .cpp extension
zazas321
Postby zazas321 » Thu Sep 23, 2021 12:35 pm
Hello. I am using ble_gatt_server_table example code. I have put all the code in my custom BLE component and split the code in BLE_custom.cpp and BLE_custom.h
BLE_custom.cpp:
#include "BLE_custom.h"
static uint8_t adv_config_done       = 0;
uint16_t heart_rate_handle_table[HRS_IDX_NB];
typedef struct {
    uint8_t                 *prepare_buf;
    int                     prepare_len;
} prepare_type_env_t;
static prepare_type_env_t prepare_write_env;
//#define CONFIG_SET_RAW_ADV_DATA
#ifdef CONFIG_SET_RAW_ADV_DATA
static uint8_t raw_adv_data[] = {
        // flags
        0x02, 0x01, 0x06,
        // tx power
        0x02, 0x0a, 0xeb,
        // service uuid
        0x03, 0x03, 0xFF, 0x00,
        // device name
        0x0f, 0x09, 'E', 'S', 'P', '_', 'G', 'A', 'T', 'T', 'S', '_', 'D','E', 'M', 'O'
static uint8_t raw_scan_rsp_data[] = {
        // flags
        0x02, 0x01, 0x06,
        // tx power
        0x02, 0x0a, 0xeb,
        // service uuid
        0x03, 0x03, 0xFF,0x00
#else
static uint8_t service_uuid[16] = {
    /* LSB <--------------------------------------------------------------------------------> MSB */
    //first uuid, 16bit, [12],[13] is the value
    0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x00,
/* The length of adv data must be less than 31 bytes */
static esp_ble_adv_data_t adv_data = {
    .set_scan_rsp        = false,
    .include_name        = true,
    .include_txpower     = true,
    .min_interval        = 0x0006, //slave connection min interval, Time = min_interval * 1.25 msec
    .max_interval        = 0x0010, //slave connection max interval, Time = max_interval * 1.25 msec
    .appearance          = 0x00,
    .manufacturer_len    = 0,    //TEST_MANUFACTURER_DATA_LEN,
    .p_manufacturer_data = NULL, //test_manufacturer,
    .service_data_len    = 0,
    .p_service_data      = NULL,
    .service_uuid_len    = sizeof(service_uuid),
    .p_service_uuid      = service_uuid,
    .flag = (ESP_BLE_ADV_FLAG_GEN_DISC | ESP_BLE_ADV_FLAG_BREDR_NOT_SPT),
// scan response data
static esp_ble_adv_data_t scan_rsp_data = {
    .set_scan_rsp        = true,
    .appearance          = 0x00,
    .p_manufacturer_data = NULL, //&test_manufacturer[0],
#endif /* CONFIG_SET_RAW_ADV_DATA */
static esp_ble_adv_params_t adv_params = {
    .adv_int_min         = 0x20,
    .adv_int_max         = 0x40,
    .adv_type            = ADV_TYPE_IND,
    .own_addr_type       = BLE_ADDR_TYPE_PUBLIC,
    .channel_map         = ADV_CHNL_ALL,
    .adv_filter_policy   = ADV_FILTER_ALLOW_SCAN_ANY_CON_ANY,
struct gatts_profile_inst {
    esp_gatts_cb_t gatts_cb;
    uint16_t gatts_if;
    uint16_t app_id;
    uint16_t conn_id;
    uint16_t service_handle;
    esp_gatt_srvc_id_t service_id;
    uint16_t char_handle;
    esp_bt_uuid_t char_uuid;
    esp_gatt_perm_t perm;
    esp_gatt_char_prop_t property;
    uint16_t descr_handle;
    esp_bt_uuid_t descr_uuid;
static void gatts_profile_event_handler(esp_gatts_cb_event_t event,
					esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param);
/* One gatt-based profile one app_id and one gatts_if, this array will store the gatts_if returned by ESP_GATTS_REG_EVT */
static struct gatts_profile_inst heart_rate_profile_tab[PROFILE_NUM] = {
    [PROFILE_APP_IDX] = {
        .gatts_cb = gatts_profile_event_handler,
        .gatts_if = ESP_GATT_IF_NONE,       /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */
/* Service */
int test_variable = 0;
static const uint16_t GATTS_SERVICE_UUID_TEST      = 0x2222;
static const uint16_t WRITE_CHARACTERISTIC       = 0x0011;
//static const uint16_t READ_CHARACTERISTIC       = 0x0012;
static const uint16_t READ_WRITE_CHARACTERISTIC       = 0x0013;
static const uint16_t primary_service_uuid         = ESP_GATT_UUID_PRI_SERVICE;
static const uint16_t character_declaration_uuid   = ESP_GATT_UUID_CHAR_DECLARE;
static const uint16_t character_client_config_uuid = ESP_GATT_UUID_CHAR_CLIENT_CONFIG;
//static const uint8_t char_prop_read                = ESP_GATT_CHAR_PROP_BIT_READ;
//static const uint8_t char_prop_write               = ESP_GATT_CHAR_PROP_BIT_WRITE;
static const uint8_t char_prop_read_write_notify   = ESP_GATT_CHAR_PROP_BIT_WRITE | ESP_GATT_CHAR_PROP_BIT_READ | ESP_GATT_CHAR_PROP_BIT_NOTIFY;
//static const uint8_t char_prop_read_notify         =  ESP_GATT_CHAR_PROP_BIT_READ | ESP_GATT_CHAR_PROP_BIT_NOTIFY;
static const uint8_t heart_measurement_ccc[2]      = {0x99, 0x55};
static const uint8_t char_value[4]                 = {0x11, 0x22, 0x33, 0x44};
/* Full Database Description - Used to add attributes into the database */
static const esp_gatts_attr_db_t gatt_db[HRS_IDX_NB] =
    // Service Declaration
    [IDX_SVC]        =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ,
      sizeof(uint16_t), sizeof(GATTS_SERVICE_UUID_TEST), (uint8_t *)&GATTS_SERVICE_UUID_TEST}},
    // WRITE Characteristic Declaration //
    [IDX_CHAR_A]     =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ,
      CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_write}},
    // Characteristic Value //
    [IDX_CHAR_VAL_A] =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&WRITE_CHARACTERISTIC, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
      GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_value), (uint8_t *)char_value}},
    // READ/NOTIFY Characteristic Declaration //
    [IDX_CHAR_B]      =
      CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read_notify}},
    [IDX_CHAR_VAL_B]  =
    {{ESP_GATT_RSP_BY_APP}, {ESP_UUID_LEN_16, (uint8_t *)&READ_CHARACTERISTIC, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
    [IDX_CHAR_CFG_B]           =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_client_config_uuid, ESP_GATT_PERM_READ|ESP_GATT_PERM_WRITE,
      sizeof(uint16_t),sizeof(heart_measurement_ccc), (uint8_t *)heart_measurement_ccc}},
//READ WRITE NOTIFY CHARACTERISTIC
    [IDX_CHAR_C]     =
      CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read_write_notify}},
    /* Characteristic Value */
    //ESP_GATT_RSP_BY_APP allows to reply with a custom respone when read again is clicked
    [IDX_CHAR_VAL_C] =
    {{ESP_GATT_RSP_BY_APP}, {ESP_UUID_LEN_16, (uint8_t *)&READ_WRITE_CHARACTERISTIC, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
    /* Client Characteristic Configuration Descriptor */
    [IDX_CHAR_CFG_C]  =
    {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_client_config_uuid, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
      sizeof(uint16_t), sizeof(heart_measurement_ccc), (uint8_t *)heart_measurement_ccc}},
static void gap_event_handler(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param)
    switch (event) {
        case ESP_GAP_BLE_ADV_DATA_RAW_SET_COMPLETE_EVT:
            adv_config_done &= (~ADV_CONFIG_FLAG);
            if (adv_config_done == 0){
                esp_ble_gap_start_advertising(&adv_params);
        case ESP_GAP_BLE_SCAN_RSP_DATA_RAW_SET_COMPLETE_EVT:
            adv_config_done &= (~SCAN_RSP_CONFIG_FLAG);
    #else
        case ESP_GAP_BLE_ADV_DATA_SET_COMPLETE_EVT:
        case ESP_GAP_BLE_SCAN_RSP_DATA_SET_COMPLETE_EVT:
    #endif
        case ESP_GAP_BLE_ADV_START_COMPLETE_EVT:
            /* advertising start complete event to indicate advertising start successfully or failed */
            if (param->adv_start_cmpl.status != ESP_BT_STATUS_SUCCESS) {
                ESP_LOGE(GATTS_TABLE_TAG, "advertising start failed");
            }else{
                ESP_LOGI(GATTS_TABLE_TAG, "advertising start successfully");
        case ESP_GAP_BLE_ADV_STOP_COMPLETE_EVT:
            if (param->adv_stop_cmpl.status != ESP_BT_STATUS_SUCCESS) {
                ESP_LOGE(GATTS_TABLE_TAG, "Advertising stop failed");
            else {
                ESP_LOGI(GATTS_TABLE_TAG, "Stop adv successfully\n");
        case ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT:
            ESP_LOGI(GATTS_TABLE_TAG, "update connection params status = %d, min_int = %d, max_int = %d,conn_int = %d,latency = %d, timeout = %d",
                  param->update_conn_params.status,
                  param->update_conn_params.min_int,
                  param->update_conn_params.max_int,
                  param->update_conn_params.conn_int,
                  param->update_conn_params.latency,
                  param->update_conn_params.timeout);
        default:
void example_prepare_write_event_env(esp_gatt_if_t gatts_if, prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param)
    ESP_LOGI(GATTS_TABLE_TAG, "prepare write, handle = %d, value len = %d", param->write.handle, param->write.len);
    esp_gatt_status_t status = ESP_GATT_OK;
    if (prepare_write_env->prepare_buf == NULL) {
        prepare_write_env->prepare_buf = (uint8_t *)malloc(PREPARE_BUF_MAX_SIZE * sizeof(uint8_t));
        prepare_write_env->prepare_len = 0;
            ESP_LOGE(GATTS_TABLE_TAG, "%s, Gatt_server prep no mem", __func__);
            status = ESP_GATT_NO_RESOURCES;
        if(param->write.offset > PREPARE_BUF_MAX_SIZE) {
            status = ESP_GATT_INVALID_OFFSET;
        } else if ((param->write.offset + param->write.len) > PREPARE_BUF_MAX_SIZE) {
            status = ESP_GATT_INVALID_ATTR_LEN;
    /*send response when param->write.need_rsp is true */
    if (param->write.need_rsp){
        esp_gatt_rsp_t *gatt_rsp = (esp_gatt_rsp_t *)malloc(sizeof(esp_gatt_rsp_t));
        if (gatt_rsp != NULL){
            gatt_rsp->attr_value.len = param->write.len;
            gatt_rsp->attr_value.handle = param->write.handle;
            gatt_rsp->attr_value.offset = param->write.offset;
            gatt_rsp->attr_value.auth_req = ESP_GATT_AUTH_REQ_NONE;
            memcpy(gatt_rsp->attr_value.value, param->write.value, param->write.len);
            esp_err_t response_err = esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, status, gatt_rsp);
            if (response_err != ESP_OK){
               ESP_LOGE(GATTS_TABLE_TAG, "Send response error");
            free(gatt_rsp);
        }else{
            ESP_LOGE(GATTS_TABLE_TAG, "%s, malloc failed", __func__);
    if (status != ESP_GATT_OK){
        return;
    memcpy(prepare_write_env->prepare_buf + param->write.offset,
           param->write.value,
           param->write.len);
    prepare_write_env->prepare_len += param->write.len;
void example_exec_write_event_env(prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param){
    if (param->exec_write.exec_write_flag == ESP_GATT_PREP_WRITE_EXEC && prepare_write_env->prepare_buf){
        esp_log_buffer_hex(GATTS_TABLE_TAG, prepare_write_env->prepare_buf, prepare_write_env->prepare_len);
    }else{
        ESP_LOGI(GATTS_TABLE_TAG,"ESP_GATT_PREP_WRITE_CANCEL");
    if (prepare_write_env->prepare_buf) {
        free(prepare_write_env->prepare_buf);
        prepare_write_env->prepare_buf = NULL;
static void gatts_profile_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
    switch (event) {
        case ESP_GATTS_REG_EVT:{
            esp_err_t set_dev_name_ret = esp_ble_gap_set_device_name(SAMPLE_DEVICE_NAME);
            if (set_dev_name_ret){
                ESP_LOGE(GATTS_TABLE_TAG, "set device name failed, error code = %x", set_dev_name_ret);
            esp_err_t raw_adv_ret = esp_ble_gap_config_adv_data_raw(raw_adv_data, sizeof(raw_adv_data));
            if (raw_adv_ret){
                ESP_LOGE(GATTS_TABLE_TAG, "config raw adv data failed, error code = %x ", raw_adv_ret);
            adv_config_done |= ADV_CONFIG_FLAG;
            esp_err_t raw_scan_ret = esp_ble_gap_config_scan_rsp_data_raw(raw_scan_rsp_data, sizeof(raw_scan_rsp_data));
            if (raw_scan_ret){
                ESP_LOGE(GATTS_TABLE_TAG, "config raw scan rsp data failed, error code = %x", raw_scan_ret);
            adv_config_done |= SCAN_RSP_CONFIG_FLAG;
    #else
            //config adv data
            esp_err_t ret = esp_ble_gap_config_adv_data(&adv_data);
            if (ret){
                ESP_LOGE(GATTS_TABLE_TAG, "config adv data failed, error code = %x", ret);
            //config scan response data
            ret = esp_ble_gap_config_adv_data(&scan_rsp_data);
            if (ret){
                ESP_LOGE(GATTS_TABLE_TAG, "config scan response data failed, error code = %x", ret);
    #endif
            esp_err_t create_attr_ret = esp_ble_gatts_create_attr_tab(gatt_db, gatts_if, HRS_IDX_NB, SVC_INST_ID);
            if (create_attr_ret){
                ESP_LOGE(GATTS_TABLE_TAG, "create attr table failed, error code = %x", create_attr_ret);
        case ESP_GATTS_READ_EVT:
            ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_READ_EVT");
            esp_gatt_rsp_t rsp;
            memset(&rsp, 0, sizeof(esp_gatt_rsp_t));
            rsp.attr_value.handle = param->read.handle;
            rsp.attr_value.len = 4;
            rsp.attr_value.value[0] = 'h';
            rsp.attr_value.value[1] = 0x54;
            rsp.attr_value.value[2] = 0x32;
            rsp.attr_value.value[3] = 0x61;
            esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, ESP_GATT_OK, &rsp);
        case ESP_GATTS_WRITE_EVT:
            if (!param->write.is_prep){
                // the data length of gattc write  must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
                ESP_LOGI(GATTS_TABLE_TAG, "GATT_WRITE_EVT, handle = %d, value len = %d, value :", param->write.handle, param->write.len);
                esp_log_buffer_hex(GATTS_TABLE_TAG, param->write.value, param->write.len);
                //WHEN DATA IS RECEIVED, SEND THE DATA TO ANOTHER CHARACTERISTIC
                // this will only work if the subscribe is on
                printf("data write event is triggered, send this data to reiceive characteristic");
                esp_ble_gatts_send_indicate(gatts_if, param->write.conn_id, heart_rate_handle_table[IDX_CHAR_VAL_B],
                                                param->write.len, param->write.value, false);
                if (heart_rate_handle_table[IDX_CHAR_CFG_C] == param->write.handle && param->write.len == 2){
                    printf("inside if statement\n");
                    uint16_t descr_value = param->write.value[1]<<8 | param->write.value[0];
                    if (descr_value == 0x0001){
                        ESP_LOGI(GATTS_TABLE_TAG, "notify enable");
                        uint8_t notify_data[15];
                        for (int i = 0; i < sizeof(notify_data); ++i)
                            notify_data[i] = i % 0xff;
                        //the size of notify_data[] need less than MTU size
                        esp_ble_gatts_send_indicate(gatts_if, param->write.conn_id, heart_rate_handle_table[IDX_CHAR_VAL_C],
                                                sizeof(notify_data), notify_data, false);
                    }else if (descr_value == 0x0002){
                        ESP_LOGI(GATTS_TABLE_TAG, "indicate enable");
                        uint8_t indicate_data[15];
                        for (int i = 0; i < sizeof(indicate_data); ++i)
                            indicate_data[i] = i % 0xff;
                        //the size of indicate_data[] need less than MTU size
                                            sizeof(indicate_data), indicate_data, true);
                    else if (descr_value == 0x0000){
                        ESP_LOGI(GATTS_TABLE_TAG, "notify/indicate disable ");
                    }else{
                        ESP_LOGE(GATTS_TABLE_TAG, "unknown descr value");
                else{
                    //printf("data received1 = %d \n",param->write.value);
                   // printf("data received2 = %s \n",param->write.value);
                    //if( strcmp(param->write.value,"hello") == 0 ){
                    //    printf("hello detexted \n");
                    //for (int i = 0; i <= param->write.len; i++){
                    //    printf("data received3 = %d \n",param->write.value[i]);
                    char * c = "Hello world";
                    uint8_t * u = (uint8_t *)c;
                    printf("size of message = %u\n",sizeof(c));
                    printf("strlen of message=%u\n",strlen(c));
                                                strlen(c), u, false);
                /* send response when param->write.need_rsp is true*/
                    printf("if param->write.need_rsp \n");
                    esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, ESP_GATT_OK, NULL);
            }else{
                /* handle prepare write */
                printf("before exmaple prepare write event env \n");
                example_prepare_write_event_env(gatts_if, &prepare_write_env, param);
        case ESP_GATTS_EXEC_WRITE_EVT:
            // the length of gattc prepare write data must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
            ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_EXEC_WRITE_EVT");
            example_exec_write_event_env(&prepare_write_env, param);
        case ESP_GATTS_MTU_EVT:
            ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_MTU_EVT, MTU %d", param->mtu.mtu);
        case ESP_GATTS_CONF_EVT:
            ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_CONF_EVT, status = %d, attr_handle %d", param->conf.status, param->conf.handle);
        case ESP_GATTS_START_EVT:
            ESP_LOGI(GATTS_TABLE_TAG, "SERVICE_START_EVT, status %d, service_handle %d", param->start.status, param->start.service_handle);
        case ESP_GATTS_CONNECT_EVT:
            ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_CONNECT_EVT, conn_id = %d", param->connect.conn_id);
            esp_log_buffer_hex(GATTS_TABLE_TAG, param->connect.remote_bda, 6);
            esp_ble_conn_update_params_t conn_params = {0};
            memcpy(conn_params.bda, param->connect.remote_bda, sizeof(esp_bd_addr_t));
            /* For the iOS system, please refer to Apple official documents about the BLE connection parameters restrictions. */
            conn_params.latency = 0;
            conn_params.max_int = 0x20;    // max_int = 0x20*1.25ms = 40ms
            conn_params.min_int = 0x10;    // min_int = 0x10*1.25ms = 20ms
            conn_params.timeout = 400;    // timeout = 400*10ms = 4000ms
            //start sent the update connection parameters to the peer device.
            esp_ble_gap_update_conn_params(&conn_params);
        case ESP_GATTS_DISCONNECT_EVT:{
            ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_DISCONNECT_EVT, reason = 0x%x", param->disconnect.reason);
        case ESP_GATTS_CREAT_ATTR_TAB_EVT:{
            if (param->add_attr_tab.status != ESP_GATT_OK){
                ESP_LOGE(GATTS_TABLE_TAG, "create attribute table failed, error code=0x%x", param->add_attr_tab.status);
            else if (param->add_attr_tab.num_handle != HRS_IDX_NB){
                ESP_LOGE(GATTS_TABLE_TAG, "create attribute table abnormally, num_handle (%d) \
                        doesn't equal to HRS_IDX_NB(%d)", param->add_attr_tab.num_handle, HRS_IDX_NB);
            else {
                ESP_LOGI(GATTS_TABLE_TAG, "create attribute table successfully, the number handle = %d\n",param->add_attr_tab.num_handle);
                memcpy(heart_rate_handle_table, param->add_attr_tab.handles, sizeof(heart_rate_handle_table));
                esp_ble_gatts_start_service(heart_rate_handle_table[IDX_SVC]);
        case ESP_GATTS_STOP_EVT:
            printf("ESP_GATTS_STOP_EVT \n");
        case ESP_GATTS_OPEN_EVT:
            printf("ESP_GATTS_OPEN_EVT \n");
        case ESP_GATTS_CANCEL_OPEN_EVT:
            printf("ESP_GATTS_CANCEL_OPEN_EVT \n");
        case ESP_GATTS_CLOSE_EVT:
            printf("ESP_GATTS_CLOSE_EVT \n");
        case ESP_GATTS_LISTEN_EVT:
            printf("ESP_GATTS_LISTEN_EVT \n");
        case ESP_GATTS_CONGEST_EVT:
            printf("ESP_GATTS_CONGEST_EVT \n");
        case ESP_GATTS_UNREG_EVT:
            printf("ESP_GATTS_UNREG_EVT \n");
        case ESP_GATTS_DELETE_EVT:
            printf("ESP_GATTS_DELETE_EVT \n");
        default:
static void gatts_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
    /* If event is register event, store the gatts_if for each profile */
    if (event == ESP_GATTS_REG_EVT) {
        if (param->reg.status == ESP_GATT_OK) {
            heart_rate_profile_tab[PROFILE_APP_IDX].gatts_if = gatts_if;
            ESP_LOGE(GATTS_TABLE_TAG, "reg app failed, app_id %04x, status %d",
                    param->reg.app_id,
                    param->reg.status);
            return;
    do {
        int idx;
        for (idx = 0; idx < PROFILE_NUM; idx++) {
            /* ESP_GATT_IF_NONE, not specify a certain gatt_if, need to call every profile cb function */
            if (gatts_if == ESP_GATT_IF_NONE || gatts_if == heart_rate_profile_tab[idx].gatts_if) {
                if (heart_rate_profile_tab[idx].gatts_cb) {
                    heart_rate_profile_tab[idx].gatts_cb(event, gatts_if, param);
    } while (0);
void BLE_setup()
    esp_err_t ret;
    ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT));
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    ret = esp_bt_controller_init(&bt_cfg);
    if (ret) {
        ESP_LOGE(GATTS_TABLE_TAG, "%s enable controller failed: %s", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
    if (ret) {
        return;
    ret = esp_bluedroid_init();
    if (ret) {
        ESP_LOGE(GATTS_TABLE_TAG, "%s init bluetooth failed: %s", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bluedroid_enable();
    if (ret) {
        ESP_LOGE(GATTS_TABLE_TAG, "%s enable bluetooth failed: %s", __func__, esp_err_to_name(ret));
        return;
    ret = esp_ble_gatts_register_callback(gatts_event_handler);
    if (ret){
        ESP_LOGE(GATTS_TABLE_TAG, "gatts register error, error code = %x", ret);
        return;
    ret = esp_ble_gap_register_callback(gap_event_handler);
    if (ret){
        ESP_LOGE(GATTS_TABLE_TAG, "gap register error, error code = %x", ret);
        return;
    ret = esp_ble_gatts_app_register(ESP_APP_ID);
    if (ret){
        ESP_LOGE(GATTS_TABLE_TAG, "gatts app register error, error code = %x", ret);
        return;
    esp_err_t local_mtu_ret = esp_ble_gatt_set_local_mtu(500);
    if (local_mtu_ret){
        ESP_LOGE(GATTS_TABLE_TAG, "set local  MTU failed, error code = %x", local_mtu_ret);
And my BLE_custom.h:
#ifndef BLE_CUSTOM_H
#define BLE_CUSTOM_H
#ifdef __cplusplus
extern "C" {
#endif
//#include "freertos/FreeRTOS.h"
//#include "freertos/task.h"
//#include "freertos/event_groups.h"
#include "esp_system.h"
#include "esp_log.h"
#include "esp_bt.h"
#include "esp_gap_ble_api.h"
#include "esp_gatts_api.h"
#include "esp_bt_main.h"
#include "esp_gatt_common_api.h"
#include "Thermostat.h"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define GATTS_TABLE_TAG "GATTS_TABLE_DEMO"
#define PROFILE_NUM                 1
#define PROFILE_APP_IDX             0
#define ESP_APP_ID                  0x55
#define SAMPLE_DEVICE_NAME          "ESP_GATTS_DEMO"
#define SVC_INST_ID                 0
/* The max length of characteristic value. When the GATT client performs a write or prepare write operation,
*  the data length must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
#define GATTS_DEMO_CHAR_VAL_LEN_MAX 500
#define PREPARE_BUF_MAX_SIZE        1024
#define CHAR_DECLARATION_SIZE       (sizeof(uint8_t))
#define ADV_CONFIG_FLAG             (1 << 0)
#define SCAN_RSP_CONFIG_FLAG        (1 << 1)
/* Attributes State Machine */
enum
    IDX_SVC,
    IDX_CHAR_A,
    IDX_CHAR_VAL_A,
    IDX_CHAR_B,
    IDX_CHAR_VAL_B,
    IDX_CHAR_CFG_B,
    IDX_CHAR_C,
    IDX_CHAR_VAL_C,
    IDX_CHAR_CFG_C,
    HRS_IDX_NB,
void BLE_setup();
#ifdef __cplusplus
#endif
#endif
All I am trying to achieve is to build this code without error. I changed the extension to .cpp because I want to include a .cpp component to this BLE_custom component and access my cpp class from the BLE_custom functions. I cannot find a way how to build this code. I am getting errors:
../components/BLE/BLE_custom.cpp:102:1: warning: missing initializer for member 'esp_ble_adv_params_t::peer_addr' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:102:1: warning: missing initializer for member 'esp_ble_adv_params_t::peer_addr_type' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::app_id' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::conn_id' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::service_handle' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::service_id' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::char_handle' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::char_uuid' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::perm' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::property' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::descr_handle' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:128:1: warning: missing initializer for member 'gatts_profile_inst::descr_uuid' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:205:1: sorry, unimplemented: non-trivial designated initializers not supported
../components/BLE/BLE_custom.cpp: In function 'void gatts_profile_event_handler(esp_gatts_cb_event_t, esp_gatt_if_t, esp_ble_gatts_cb_param_t*)':
../components/BLE/BLE_custom.cpp:441:32: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
../components/BLE/BLE_custom.cpp:486:58: warning: missing initializer for member 'esp_ble_conn_update_params_t::min_int' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:486:58: warning: missing initializer for member 'esp_ble_conn_update_params_t::max_int' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:486:58: warning: missing initializer for member 'esp_ble_conn_update_params_t::latency' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:486:58: warning: missing initializer for member 'esp_ble_conn_update_params_t::timeout' [-Wmissing-field-initializers]
../components/BLE/BLE_custom.cpp:496:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:486:42: note:   crosses initialization of 'esp_ble_conn_update_params_t conn_params'
../components/BLE/BLE_custom.cpp:501:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:518:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:521:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:524:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:527:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:530:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:533:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:536:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:539:14: error: jump to case label [-fpermissive]
../components/BLE/BLE_custom.cpp:542:9: error: jump to case label [-fpermissive]
         default:
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_UNREG_EVT' not handled in switch [-Werror=switch]
     switch (event) {
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_CREATE_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_ADD_INCL_SRVC_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_ADD_CHAR_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_ADD_CHAR_DESCR_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_DELETE_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_STOP_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_DISCONNECT_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_OPEN_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_CANCEL_OPEN_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_CLOSE_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_LISTEN_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_CONGEST_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_RESPONSE_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_CREAT_ATTR_TAB_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_SET_ATTR_VAL_EVT' not handled in switch [-Werror=switch]
../components/BLE/BLE_custom.cpp:329:12: error: enumeration value 'ESP_GATTS_SEND_SERVICE_CHANGE_EVT' not handled in switch [-Werror=switch]
cc1plus.exe: some warnings being treated as errors
Cannot understand why I am getting so many errors. It complains a lot about the switch statements not being handled but I have all of them and that should not be an issue.
mbratch
Re: How to compile BLE example code with .cpp extension
Postby mbratch » Fri Sep 24, 2021 8:33 pm
Since you haven't included any C++ components yet, perhaps ensure first that it compiles as a C file to make sure you copied things over properly. Then change it to cpp. C++ does have some different rules (it is a different language than C!) but then at least you've eliminated possible basic errors.
chegewara
Postby chegewara » Fri Sep 24, 2021 10:04 pm
Users browsing this forum: Bing [Bot] and 218 guests
