ESP32-C3-MINI socket连接
wwwwwwww
Postby wwwwwwww » Sun Sep 26, 2021 3:58 am
C3为服务端,一个设备不停的断开连接再重新连接C3,站点数也会增加,在断开连接时并不会减少站点数.导致多次以后,超过了最大站点连接数.请问有什么解决办法吗
wwwwwwww
Re: ESP32-C3-MINI socket连接
Postby wwwwwwww » Sun Sep 26, 2021 4:04 am
Code: Untitled.c Select all
 for (;;)
// initialize file descriptor set
FD_ZERO(&fdsr);
FD_SET(listen_sock, &fdsr);
// timeout setting
tv.tv_sec = 60;
tv.tv_usec = 0;
// add active connection to fd set
for (i = 0; i < BACKLOG; i++) {
if (fd_A[i] != 0) {
FD_SET(fd_A[i], &fdsr);
//block here until listen_sock can read
int ret = select(maxsockfd+1, &fdsr, NULL, NULL, &tv);
if (ret < 0) {
perror("select");
} else if (ret == 0) {
printf("timeout\n");
continue;
// check every fd in the set and handle the recv()
for (i = 0; i < conn_amount; i++)
if (FD_ISSET(fd_A[i], &fdsr))
ret = recv(fd_A[i], rx_buffer, sizeof(rx_buffer) - 1, 0);
ret1= ret;
station = i;
if (ret <= 0)
{ // client close
ESP_LOGE(TAG, "recv failed or connection closed: errno %d", errno);
printf("client[%d] close\n", i);
close(fd_A[i]);
FD_CLR(fd_A[i], &fdsr);
fd_A[i] = 0;
// conn_amount=0;
else
{ // receive data
//printf("star\n");
if (ret < BUF_SIZE)
memset(&rx_buffer[ret], '\0', 1);
printf("client[%d] send:%s\n", i, rx_buffer);
ctl_mode = rx_buffer[0];
//Uart0Recv(i,rx_buffer,ret);
/*int err = send(fd_A[i], rx_buffer, ret, 0);
if (err < 0) {
ESP_LOGE(TAG, "Error occured during sending: errno %d", errno);
continue;
// check whether a new connection comes and handler the new connection
if (FD_ISSET(listen_sock, &fdsr)) {
int connect_sock = accept(listen_sock, (struct sockaddr *)&client_addr, &addrLen);
if (connect_sock <= 0) {
perror("accept");
continue;
ESP_LOGI(TAG, "Socket accepted");
// add to fd queue
if (conn_amount < BACKLOG)
fd_A[conn_amount++] = connect_sock;
printf("new connection client[%d] %s:%d\n", conn_amount,
inet_ntoa(client_addr.sin_addr), ntohs(client_addr.sin_port));
if (connect_sock > maxsockfd)
maxsockfd = connect_sock;
else {
printf("max connections arrive, exit\n");
send(connect_sock, "bye", 4, 0);
close(connect_sock);
continue;
//showclient();
// when select() return error, close other connections
ESP_LOGE(TAG, "Shutting down socket and restarting...");
if (fd_A[i] != 0) {
shutdown(fd_A[i], 0);
close(fd_A[i]);
YJM
Postby YJM » Sun Sep 26, 2021 9:01 am
你关闭 socket 的时候可以选择强制关闭 socket。 使用 SO_LINGER 选项。具体可以参考 viewtopic.php?f=13&t=20705
