JTAG debugging in Eclipse
alqine
Postby alqine » Fri Oct 01, 2021 12:08 pm
Hi guys, for last two weeks I am battling with Eclipse. What I want to do is enable JTAG debugging. My JTAG adapter of choice is generic FT232H.
I downloaded brand new Eclipse CDT 2021-06, since 2021-09 does not work yet. Then I proceded with ESP-IDF plugin installation and Debug Setup.
I had existing project, so I created new project from template given by the editor and then copy-pasted my existing code into the folder. Maybe that is the problem?
Then I flashed the project onto my board. I am using OpenOCD board esp-wroom-32.cfg and interface ftdi/esp32_devkitj_v1.cfg with small changes to support my FT232H debugger.
When I start debugging, I got those warnings:
Warn : Empty flash mapping!
Warn : Failed to get flash mappings (0)!
and
I don't know, whether the first one has any significance, but the second one means, that GDB was started before loading elf file. How can I change the order?
The most prominent problem is that when app_main breakpoint is reached (or when the debug startup process finishes) I am getting:
Break at address "0x4000939b" with no debug information available, or outside of program code.
I am using custom partitions.csv:
# Documentation: https://www.notion.so/partitions-cvs-e8cf552fe1864a0b9aa5981fbc0b8e4f
# Name,   Type, SubType, Offset,  Size, Flags
nvs,      data, nvs,     ,  16K,
ota_data,  data, ota,    ,  8K,
phy_init, data, phy,     ,  4K,
ota_0,    app,  ota_0,   ,  1M,
ota_1,    app,  ota_1,   , 1M,
In addition, I am using MacOS 11.6 with M1 chip. ESP is connected via monitor's USB hub.
Would you please give me a tips how to get debugging working? I don't insist on using Eclipse, since I hate this editor, but results are same both on Windows using Eclipse or Platformio.
Console dump:
Code: Untitled.txt Select all
Open On-Chip Debugger  v0.10.0-esp32-20210401 (2021-04-01-15:46)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
Flashing /Users/user/eclipse-workspace/main_unit_eclipse/build/partition_table/partition-table.bin at 0x8000
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : esp32.cpu0: Target halted, PC=0x40091C2A, debug_reason=00000001
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Auto-detected flash bank 'esp32.cpu1.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu1.flash' size 4096 KB
** Programming Started **
Info : PROF: Data transferred in 21.868 ms @ 182.916 KB/s
** Programming Finished **
** Verify Started **
Info : PROF: Data transferred in 19.893 ms @ 150.807 KB/s
** Verified OK **
** Flashing done for partition_table/partition-table.bin **
Flashing /Users/user/eclipse-workspace/main_unit_eclipse/build/bootloader/bootloader.bin at 0x1000
Info : PROF: Data transferred in 138.313 ms @ 289.199 KB/s
Info : PROF: Data transferred in 123.771 ms @ 299.949 KB/s
** Verified OK **
** Flashing done for bootloader/bootloader.bin **
Flashing /Users/user/eclipse-workspace/main_unit_eclipse/build/main_unit.bin at 0x10000
Info : PROF: Data transferred in 804.556 ms @ 258.528 KB/s
Info : PROF: Data transferred in 638.598 ms @ 319.964 KB/s
** Verified OK **
** Flashing done for main_unit.bin **
Flashing /Users/user/eclipse-workspace/main_unit_eclipse/build/ota_data_initial.bin at 0xd000
Info : PROF: Data transferred in 30.435 ms @ 262.855 KB/s
Info : PROF: Data transferred in 31.587 ms @ 253.269 KB/s
** Verified OK **
** Flashing done for ota_data_initial.bin **
** Resetting Target **
0
Started by GNU MCU Eclipse
Info : esp32.cpu0: Target halted, PC=0x4000939B, debug_reason=00000000
Info : esp32.cpu1: Target halted, PC=0x400076DD, debug_reason=00000000
Info : Using flash bank 'esp32.cpu0.irom' size 0 KB
Info : Using flash bank 'esp32.cpu0.drom' size 0 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
invalid command name "arm"
===== Xtensa registers
(0) pc (/32): 0x40000400
(1) ar0 (/32): 0x00000000
(2) ar1 (/32): 0x00000000
(3) ar2 (/32): 0x00000000
(4) ar3 (/32): 0x00000000
(5) ar4 (/32): 0x00000000
(6) ar5 (/32): 0x00000000
(7) ar6 (/32): 0x00000000
(8) ar7 (/32): 0x00000000
(9) ar8 (/32): 0x00000000
(10) ar9 (/32): 0x00000000
(11) ar10 (/32): 0x00000000
(12) ar11 (/32): 0x00000000
(13) ar12 (/32): 0x00000000
(14) ar13 (/32): 0x00000000
(15) ar14 (/32): 0x00000000
(16) ar15 (/32): 0x00000000
(17) ar16 (/32): 0x00000000
(18) ar17 (/32): 0x00000000
(19) ar18 (/32): 0x00000000
(20) ar19 (/32): 0x00000000
(21) ar20 (/32): 0x00000000
(22) ar21 (/32): 0x00000000
(23) ar22 (/32): 0x00000000
(24) ar23 (/32): 0x00000000
(25) ar24 (/32): 0x00000000
(26) ar25 (/32): 0x00000000
(27) ar26 (/32): 0x00000000
(28) ar27 (/32): 0x00000000
(29) ar28 (/32): 0x00000000
(30) ar29 (/32): 0x00000000
(31) ar30 (/32): 0x00000000
(32) ar31 (/32): 0x00000000
(33) ar32 (/32): 0x00000000
(34) ar33 (/32): 0x00000000
(35) ar34 (/32): 0x00000000
(36) ar35 (/32): 0x00000000
(37) ar36 (/32): 0x00000000
(38) ar37 (/32): 0x00000000
(39) ar38 (/32): 0x00000000
(40) ar39 (/32): 0x00000000
(41) ar40 (/32): 0x00000000
(42) ar41 (/32): 0x00000000
(43) ar42 (/32): 0x00000000
(44) ar43 (/32): 0x00000000
(45) ar44 (/32): 0x00000000
(46) ar45 (/32): 0x00000000
(47) ar46 (/32): 0x00000000
(48) ar47 (/32): 0x00000000
(49) ar48 (/32): 0x00000000
(50) ar49 (/32): 0x00000000
(51) ar50 (/32): 0x00000000
(52) ar51 (/32): 0x00000000
(53) ar52 (/32): 0x00000000
(54) ar53 (/32): 0x00000000
(55) ar54 (/32): 0x00000000
(56) ar55 (/32): 0x00000000
(57) ar56 (/32): 0x00000000
(58) ar57 (/32): 0x00000000
(59) ar58 (/32): 0x00000000
(60) ar59 (/32): 0x00000000
(61) ar60 (/32): 0x00000000
(62) ar61 (/32): 0x00000000
(63) ar62 (/32): 0x00000000
(64) ar63 (/32): 0x00000000
(65) lbeg (/32): 0x00000000
(66) lend (/32): 0x00000000
(67) lcount (/32): 0x00000000
(68) sar (/32): 0x00000000
(69) windowbase (/32): 0x00000000
(70) windowstart (/32): 0x00000001
(71) configid0 (/32): 0x40000400
(72) configid1 (/32): 0x1CC5FE96
(73) ps (/32): 0x0000001F
(74) threadptr (/32): 0x00000000
(75) br (/32): 0x00000000
(76) scompare1 (/32): 0x00000000
(77) acclo (/32): 0x00000000
(78) acchi (/32): 0x00000000
(79) m0 (/32): 0x00000000
(80) m1 (/32): 0x00000000
(81) m2 (/32): 0x00000000
(82) m3 (/32): 0x00000000
(83) f0 (/32): 0x00000000
(84) f1 (/32): 0x00000000
(85) f2 (/32): 0x00000000
(86) f3 (/32): 0x00000000
(87) f4 (/32): 0x00000000
(88) f5 (/32): 0x00000000
(89) f6 (/32): 0x00000000
(90) f7 (/32): 0x00000000
(91) f8 (/32): 0x00000000
(92) f9 (/32): 0x00000000
(93) f10 (/32): 0x00000000
(94) f11 (/32): 0x00000000
(95) f12 (/32): 0x00000000
(96) f13 (/32): 0x00000000
(97) f14 (/32): 0x00000000
(98) f15 (/32): 0x00000000
(99) fcr (/32): 0x00000000
(100) fsr (/32): 0x00000000
(101) mmid (/32)
(102) ibreakenable (/32): 0x00000000
(103) memctl (/32): 0x00000000
(104) atomctl (/32): 0x00000028
(105) ibreaka0 (/32): 0x00000000
(106) ibreaka1 (/32): 0x00000000
(107) dbreaka0 (/32): 0x00000000
(108) dbreaka1 (/32): 0x00000000
(109) dbreakc0 (/32): 0x00000000
(110) dbreakc1 (/32): 0x00000000
(111) epc1 (/32): 0x00000000
(112) epc2 (/32): 0x00000000
(113) epc3 (/32): 0x00000000
(114) epc4 (/32): 0x00000000
(115) epc5 (/32): 0x00000000
(116) epc6 (/32): 0x40000400
(117) epc7 (/32): 0x00000000
(118) depc (/32): 0x00000000
(119) eps2 (/32): 0x00000000
(120) eps3 (/32): 0x00000000
(121) eps4 (/32): 0x00000000
(122) eps5 (/32): 0x00000000
(123) eps6 (/32): 0x0000001F
(124) eps7 (/32): 0x00000000
(125) excsave1 (/32): 0x00000000
(126) excsave2 (/32): 0x00000000
(127) excsave3 (/32): 0x00000000
(128) excsave4 (/32): 0x00000000
(129) excsave5 (/32): 0x00000000
(130) excsave6 (/32): 0x00000000
(131) excsave7 (/32): 0x00000000
(132) cpenable (/32): 0x000000FF
(133) interrupt (/32): 0x00018040
(134) intset (/32)
(135) intclear (/32)
(136) intenable (/32): 0x00000000
(137) vecbase (/32): 0x40000000
(138) exccause (/32): 0x00000000
(139) debugcause (/32): 0x00000020
(140) ccount (/32): 0x00000004
(141) prid (/32): 0x0000CDCD
(142) icount (/32): 0x00000000
(143) icountlevel (/32): 0x00000000
(144) excvaddr (/32): 0x00000000
(145) ccompare0 (/32): 0x00000000
(146) ccompare1 (/32): 0x00000000
(147) ccompare2 (/32): 0x00000000
(148) misc0 (/32): 0x00000000
(149) misc1 (/32): 0x00000000
(150) misc2 (/32): 0x00000000
(151) misc3 (/32): 0x00000000
(163) a0 (/32): 0x00000000
(164) a1 (/32): 0x00000000
(165) a2 (/32): 0x00000000
(166) a3 (/32): 0x00000000 (dirty)
(167) a4 (/32): 0x00000000
(168) a5 (/32): 0x00000000
(169) a6 (/32): 0x00000000
(170) a7 (/32): 0x00000000
(171) a8 (/32): 0x00000000
(172) a9 (/32): 0x00000000
(173) a10 (/32): 0x00000000
(174) a11 (/32): 0x00000000
(175) a12 (/32): 0x00000000
(176) a13 (/32): 0x00000000
(177) a14 (/32): 0x00000000
(178) a15 (/32): 0x00000000
(179) pwrctl (/32)
(180) pwrstat (/32)
(181) eristat (/32)
(182) cs_itctrl (/32)
(183) cs_claimset (/32)
(184) cs_claimclr (/32)
(185) cs_lockaccess (/32)
(186) cs_lockstatus (/32)
(187) cs_authstatus (/32)
(188) fault_info (/32)
(189) trax_id (/32)
(190) trax_ctrl (/32)
(191) trax_stat (/32)
(192) trax_data (/32)
(193) trax_addr (/32)
(194) trax_pctrigger (/32)
(195) trax_pcmatch (/32)
(196) trax_delay (/32)
(197) trax_memstart (/32)
(198) trax_memend (/32)
(199) pmg (/32)
(200) pmoc (/32)
(201) pm0 (/32)
(202) pm1 (/32)
(203) pmctrl0 (/32)
(204) pmctrl1 (/32)
(205) pmstat0 (/32)
(206) pmstat1 (/32)
(207) ocd_id (/32)
(208) ocd_dcrclr (/32)
(209) ocd_dcrset (/32)
(210) ocd_dsr (/32)
(211) ddr (/32)
(212) expstate (/32): 0x00000000
(213) f64r_lo (/32): 0x00000000
(214) f64r_hi (/32): 0x00000000
(215) f64s (/32): 0x00000000
Users browsing this forum: Baidu [Spider], PerplexityBot, Semrush [Bot] and 5 guests
