ESP32 dfrobot SPI pinout
Orion3570
Postby Orion3570 » Sat Oct 02, 2021 8:14 pm
Hello there!
I need to use additional device that connects through SPI but I don't really know which pins i should use to do this.
The pinout of the board described on the image is very confusing and I've searched some topics about ESP32, yet, there is always a pin or two that is not led out to the board.
So, is there a way to solve this problem so I can connect my device to SPI?
Mentioned board
https://wiki.dfrobot.com/e-Ink_Display_ ... KU_DFR0676
_0b00t_
Re: ESP32 dfrobot SPI pinout
Postby _0b00t_ » Thu Nov 18, 2021 6:05 pm
You can check on the global esp32 pinout reference to know what default spi pins to use.
By the way, you can attach the SPI bus on your desired pins thanks to the GPIO matrix.
