Distance Sensor Mid-Long Range
kyrpav
Postby kyrpav » Sun Oct 03, 2021 1:48 pm
I am interesting on distance sensor that is able to detect distance up to 20m. I suppose some reflective surface should exist on the other side.
The idea is that we have some spot like a net and we need to calculate the distance from it, so some reflective surface can exists in the "net" and the sensor should be able to calculate the distance to this reflective surface.
The sensor will be placed on object that could move and based on some motors turning left or right should be able to detect the distance.
I can not find any sensor for this purpose , is there any category (i suppose a led distance sensor) or exact sensor that i can use for these reasons or any other better idea
tommeyers
Re: Distance Sensor Mid-Long Range
Postby tommeyers » Sun Oct 03, 2021 11:16 pm
Ultrasonic? IR?
IT Professional, Maker
Santiago, Dominican Republic
kyrpav
Postby kyrpav » Tue Oct 05, 2021 6:22 am
Do you have any specific item? that i could use?
Until now i have these options:
https://www.terabee.com/shop/lidar-tof- ... r-evo-40m/
https://www.terabee.com/shop/lidar-tof- ... r-evo-60m/
https://buy.garmin.com/en-US/US/p/557294
https://www.aliexpress.com/item/32823813140.html
But if you see the next one i would like to find a sensor like this where if the product is so inexpensive then also the sensor is the same but i do not know what they use and what is needed:
https://www.aliexpress.com/item/3282553 ... 9376%22%7D
