Native ESP32 MQTT library Secure connection error
zekageri
Postby zekageri » Thu Oct 07, 2021 7:15 am
Hello everyone.
I want to setup an MQTT client on my esp. I was able to do it without SSL, and it is working fine with cloud mqtt providers if it is not secure. I used it with https://www.emqx.com/en/cloud and it was good. Now i want to implement secure connection feature.
For this, i pick https://www.hivemq.com because it is free and allows secure connections. I got a CA from the server with openssl on windows with the following command:
openssl s_client -connect <IDHERE>accountID</IDHERE>.s2.eu.hivemq.cloud:8883
If i generate a PEM CA with keytool like this:
keytool -exportcert -keystore hivemq.jks -alias hivemq -keypass <PWHERE> -storepass <PWHERE>-rfc -file hivemq-server-cert.pem
I got the exact same error from the ESP
The CA looks fine for me. ( I also tried with other CAs like one of my own CA from https://zerossl.com but it obviously did not work since the dns does not match )
I got the following error on the ESP32 side on the Serial.
E (25952) esp-tls: mbedtls_ssl_handshake returned -0x2700
E (25956) esp-tls: Failed to open new connection
E (25956) TRANS_SSL: Failed to open a new connection
E (25957) MQTT_CLIENT: Error transport connect
It seems to me that the CA is not okay.
Here is my sketch:
const char* mqttServer = "mqtts://<IDHERE>accountID</IDHERE>.s1.eu.hivemq.cloud";
const char* mqtt_user = "test";
const char* mqtt_pwd = "test1234567";
esp_mqtt_client_config_t mqtt_cfg;
esp_mqtt_client_handle_t mqtt_client;
const char* pemFile = R"literal(
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----)literal";
inline esp_err_t mqttEvent(esp_mqtt_event_handle_t event) {
    esp_mqtt_client_handle_t mqttclient = event->client;
    switch (event->event_id) {
        case MQTT_EVENT_CONNECTED:
            onMqttConnect(mqttclient);
        case MQTT_EVENT_DISCONNECTED:
            mqttConnected = false;
        case MQTT_EVENT_DATA:
            onMqttData(event);
        default:
    return ESP_OK;
const size_t mqttJsonSize = 15000;
String mqttBuffer;
static const inline void setupMQTT(){
    mqttBuffer.reserve(mqttJsonSize);
    Serial.print("mqtt_setup: "); Serial.println(mqttServer);
    mqtt_cfg.event_handle   =   mqttEvent;
    mqtt_cfg.uri            =   mqttServer;
    //mqtt_cfg.port           =   15902; // this port is working fine with non ssl connection
    mqtt_cfg.port           =   8883; // current mqtts port.
    //mqtt_cfg.task_stack     =   10048; // it was just a test
    mqtt_cfg.username=(const char *)mqtt_user;
    mqtt_cfg.password=(const char *)mqtt_pwd;
    //mqtt_cfg.use_secure_element = true;  // not supported error?
    mqtt_cfg.cert_pem       =   (const char *)pemFile;
    //mqtt_cfg.client_key_pem =   (const char *)keyPemFile; // it was a test. i did not get a key with the openssl command.
    mqtt_client = esp_mqtt_client_init(&mqtt_cfg);
    if( esp_mqtt_client_start(mqtt_client) == ESP_OK){
        Serial.println("MQTT init success.");  // this line prints with or without TLS
    }else{
        Serial.println("Problem on mqtt INIT");
void onMqttConnect(esp_mqtt_client_handle_t client) {
    mqttConnected = true;
    esp_mqtt_client_subscribe(client, receiveTopic, 0);
    Serial.print("subscribed to: "); Serial.println(receiveTopic);
void onMqttData(esp_mqtt_event_handle_t event) {
    // working with non SSL
    boolean packageOk = false;
    mqttBuffer += String(event->data).substring(0, event->data_len);
    if(mqttBuffer.length() >= event->total_data_len){packageOk = true;}
    if(packageOk){
     // packet is ok to process.
open ssl command response in CMD:
CONNECTED(000001A4)
depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
verify error:num=20:unable to get local issuer certificate
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = *.s2.eu.hivemq.cloud
verify return:1
Certificate chain
 0 s:CN = *.s2.eu.hivemq.cloud
   i:C = US, O = Let's Encrypt, CN = R3
 1 s:C = US, O = Let's Encrypt, CN = R3
   i:C = US, O = Internet Security Research Group, CN = ISRG Root X1
 2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
   i:O = Digital Signature Trust Co., CN = DST Root CA X3
Server certificate
<HERE IS THE CA></HERE IS THE CA>
subject=CN = *.s2.eu.hivemq.cloud
issuer=C = US, O = Let's Encrypt, CN = R3
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: X25519, 253 bits
SSL handshake has read 4520 bytes and written 446 bytes
Verification error: unable to get local issuer certificate
New, TLSv1.2, Cipher is ECDHE-RSA-AES128-GCM-SHA256
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : ECDHE-RSA-AES128-GCM-SHA256
    Session-ID: <sessionid>
    Session-ID-ctx:
    Master-Key: <masterkey>
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    Start Time: 1633589568
    Timeout   : 7200 (sec)
    Verify return code: 20 (unable to get local issuer certificate)
    Extended master secret: yes
closed
MY current heap consumption with TLS:
  • TOTAL_SKETCH 3.13 MB
    USED_SKETCH 1.47 MB
    TOTAL_HEAP 303.21 KB
    FREE_HEAP 104.5 KB
    TOTAL_PSRAM 4 MB
    FREE_PSRAM 3.89 MB
    USED_PSRAM 109.47 KB
    TOTAL_FS 9.69 MB
    USED_FS 780 KB
    FREE_FS 8.93 MB
I'm using an ESP32-WROVER-E bare chip with 16mb FLASH and 4mb external RAM.
Also i'm not using WiFi, instead of a LAN8720 Ethernet Chip with the built in ETH library.
( every http or https request is working fine to my server with the zerossl CA and it is also running an Async webserver which is working fine too )
Thank you for your help.
mitja123
Re: Native ESP32 MQTT library Secure connection error
Postby mitja123 » Tue Oct 26, 2021 12:31 am
have you solved this issue? I am getting the same 0x2700 error while trying to connect to the mqtt broker. See post:
https://www.esp32.com/viewtopic.php?f=13&t=23832
