The official doc suggest build toolchain on linux, but unforturnately I am not so familar with it.
So, could esp32 provide a guide on building a toolchain on Windows?
Thks in advance.
How to build a develop environment on windows?
Re: How to build a develop environment on windows?
Thks
but whil clone from git, got error message as follows:
$ git clone --recursive https://github.com/espressif/esp-idf.git
正克隆到 'esp-idf'...
remote: Counting objects: 3525, done.
remote: Compressing objects: 100% (349/349), done.
remote: Total 3525 (delta 220), reused 0 (delta 0), pack-reused 3162
接收对象中: 100% (3525/3525), 5.26 MiB | 170.00 KiB/s, 完成.
处理 delta 中: 100% (1915/1915), 完成.
检查连接... 完成。
子模组 'components/esp32/lib'(https://github.com/espressif/esp32-wifi-lib.git)未对路径 'components/esp32/lib' 注册
子模组 'components/esptool_py/esptool'(https://github.com/themadinventor/esptool.git)未对路径 'components/esptool_py/esptool' 注册
正克隆到 '/c/esp32/esp-idf/components/esp32/lib'...
正克隆到 '/c/esp32/esp-idf/components/esptool_py/esptool'...
': 不是有效的标识符t.sh: 第 89 行:export: `sha1
': 不是有效的标识符t.sh: 第 89 行:export: `displaypath
▒▒ģ▒▒·▒▒ ''▒▒▒▒▒ '9f26b9a190e6a6ca42656685df9287253badfa46'
▒▒ģ▒▒·▒▒ ''▒▒▒▒▒ '7c84dd433512bac80e4c01c569e42b4fe76646a7'
正克隆到 'esp-idf'...
检查连接... 完成。
This is a known issue: https://github.com/espressif/esp-idf/issues/11 The messages themselves are harmless, everything should still just work.
Users browsing this forum: Bing [Bot], ChatGPT-User, Google [Bot], Qwantbot and 1 guest
