ESP32 WiFi goes OFF when output pin is continuously toggled
Posted: Sun Oct 17, 2021 3:50 pm
by chuxyz
I'm having challenge with my ESP32 Dev board. Whenever I connect to wifi and try to trigger the output pin, everything seems to work fine except that the WiFi goes OFF at some point and does not come ON until I switch OFF and then ON the power supply. Anyone know what the problem is?
Re: ESP32 WiFi goes OFF when output pin is continuously toggled
Posted: Mon Oct 18, 2021 12:48 am
by Sprite
Can you share code? What do you mean with 'wifi goes OFF', can you share serial logs when that happens?
Posted: Mon Oct 18, 2021 9:27 am
by chuxyz
I don't think the problem is with my code because everything works fine when plug ESP board to my PC. The problem only happens when I connect ESP board to my circuit to switch load. What I mean by WiFi goes OFF is that the WiFi network disappears completely and only reappears when I switch OFF and ON power supply.
Posted: Tue Oct 19, 2021 12:53 am
by Sprite
to switch load.
Ah, you didn't mention that before. What circuit are you using, can you post a schematic, or at least tell us what components are involved?
Posted: Tue Oct 19, 2021 8:06 am
by felmue
Hello @chuxyz
you might need something like a snubber (https://en.wikipedia.org/wiki/Snubber) to reduce EMI. I had a similar issue where I could switch a relay by itself just fine, but some weird stuff started to happen when I attached a light bulb to the relay. Adding a snubber fixed the issue for me.
Felix
Posted: Wed Oct 20, 2021 9:18 pm
by chuxyz
to switch load.
My circuit is a very simple one. Output pin of ESP circuit triggers a 5Vdc relay which in turn triggers a 220Vac relay that powers a single phase electric motor. I used a linear power supply to power ESP board
Posted: Wed Oct 20, 2021 9:19 pm
by chuxyz
to switch load.
Output pin of ESP circuit triggers a 5Vdc relay which in turn triggers a 220Vac relay that powers a single phase electric motor. I used a linear power supply to power ESP board.
Posted: Wed Oct 20, 2021 9:34 pm
by chuxyz
Hello @chuxyz
Felix
Thank you Felix.
Should the snubber be in parallel with relay contact or with the load?
Posted: Thu Oct 21, 2021 8:17 am
by felmue
Hello @chuxyz
In my case I used an RC snubber with is in parallel to the relay contact.
Please be careful when doing experiments with mains voltages.
Felix
