I would like to allocate some variables in the ROM memory address of the Espressif, so I can acess to them, change it's value and keep its value constant between each turn off-on process.
I know I can do it with an EEPROM memory, but I would prefer not using this peripheral.
How do I allocate those variables?<br/>
I'm coding in C and using ESP-IDF Eclipse and CMAKE to build the project.<br/>
Thanks,
Pablo
ESP32 fixed variables in ROM
Re: ESP32 fixed variables in ROM
The ROM in ESP chips is Mask ROM not EEPROM. So it is literally Read Only Memory.
As an alternative, nvs probably approximates what you want (although you still need to save your values manually)
Users browsing this forum: Qwantbot and 6 guests
