HI
I have a simple circuit with 2 x ESP32-Cams. They talk to each other with U0Tx -> U0Rx interconnected both boards.
One board (board1) also has an SD card inserted (using 1 bit mode, so IO4 is disconnected from the SDcard carrier)
When I power up the circuit, board 1 does not boot by program unless I disconnect it's U0Rx from the board 2
Boot of board 2 is not affected in the same way, and switching the two boards makes no difference.
Also, they both run the same code.
I've tried a number of these boards,. including some brand new ones.
Now - saying it doesn't boot isn't 100%. It gets this far.
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
Thats where is stops.
A good boot looks like this
ho 0 tail 12 room 4
entry 0x400806b4
Number 5 is alive
SD_MMC Card Type: SDSC
SD_MMC Card Size: 1910MB
Total space: 1909MB
Used space: 0MB
....and so on.
What exists in this preboot-loader that stops my program from running ?
Anyone know ?
I should add that if I disconnect the Rx line, power up, it boots. Then I can connect the Rx line back to board 2 Tx, and they chat together like best buddies.
Hardy
ESP32-Cam Serial U0Rx causing boot failure - multiple devices
Users browsing this forum: Google [Bot] and 2 guests
