ESP32的I2S同步时钟BCK最高输出时钟达不到手册标的40MHZ
mr_jing
Postby mr_jing » Mon Nov 22, 2021 9:51 am
在idf的例程中复制项目i2s_basic,我尝试修改采样率来提高i2s的频率,当我设置采样率到150000,使用逻辑分析仪测量bck_io的频率为9.7MHz,我接着往大的设置,尝试了250000,350000....625000。发现bck_io的频率最高只能到15MHZ,设置高了也没有效果。
/* I2S Example
    This example code will output 100Hz sine wave and triangle wave to 2-channel of I2S driver
    Every 5 seconds, it will change bits_per_sample [16, 24, 32] for i2s data
#include <stdio.h>
#include "freertos/task.h"
#include "driver/i2s.h"
#include "driver/gpio.h"
#include "esp_system.h"
#include "esp_log.h"
#include <math.h>
#define SAMPLE_RATE     (150000)
#define I2S_NUM         (0)
#define WAVE_FREQ_HZ    (100)
#define PI              (3.14159265)
#define I2S_BCK_IO      (GPIO_NUM_4)
#define I2S_WS_IO       (GPIO_NUM_5)
#define I2S_DO_IO       (-1)
#define I2S_DI_IO       (GPIO_NUM_18)
#define SAMPLE_PER_CYCLE (SAMPLE_RATE/WAVE_FREQ_HZ)
static const char* TAG = "i2s_example";
int16_t i2s_readraw_buff[400];
static void setup_triangle_sine_waves(int bits)
    int *samples_data = malloc(((bits+8)/16)*SAMPLE_PER_CYCLE*4);
    unsigned int i, sample_val;
    double sin_float, triangle_float, triangle_step = (double) pow(2, bits) / SAMPLE_PER_CYCLE;
    size_t i2s_bytes_write = 0;
    printf("\r\nTest bits=%d free mem=%d, written data=%d\n", bits, esp_get_free_heap_size(), ((bits+8)/16)*SAMPLE_PER_CYCLE*4);
    triangle_float = -(pow(2, bits)/2 - 1);
    for(i = 0; i < SAMPLE_PER_CYCLE; i++) {
        sin_float = sin(i * 2 * PI / SAMPLE_PER_CYCLE);
        if(sin_float >= 0)
            triangle_float += triangle_step;
        else
            triangle_float -= triangle_step;
        sin_float *= (pow(2, bits)/2 - 1);
        if (bits == 16) {
            sample_val = 0;
            sample_val += (short)triangle_float;
            sample_val = sample_val << 16;
            sample_val += (short) sin_float;
            samples_data[i] = sample_val;
        } else if (bits == 24) { //1-bytes unused
            samples_data[i*2] = ((int) triangle_float) << 8;
            samples_data[i*2 + 1] = ((int) sin_float) << 8;
            samples_data[i*2] = ((int) triangle_float);
            samples_data[i*2 + 1] = ((int) sin_float);
    ESP_LOGI(TAG, "set clock");
    i2s_set_clk(I2S_NUM, SAMPLE_RATE, bits, 2);
    //Using push
    // for(i = 0; i < SAMPLE_PER_CYCLE; i++) {
    //     if (bits == 16)
    //         i2s_push_sample(0, &samples_data[i], 100);
    //     else
    //         i2s_push_sample(0, &samples_data[i*2], 100);
    // or write
    ESP_LOGI(TAG, "write data");
    i2s_write(I2S_NUM, samples_data, ((bits+8)/16)*SAMPLE_PER_CYCLE*4, &i2s_bytes_write, 100);
    free(samples_data);
void app_main(void)
    //for 36Khz sample rates, we create 100Hz sine wave, every cycle need 36000/100 = 360 samples (4-bytes or 8-bytes each sample)
    //depend on bits_per_sample
    //using 6 buffers, we need 60-samples per buffer
    //if 2-channels, 16-bit each channel, total buffer is 360*4 = 1440 bytes
    //if 2-channels, 24/32-bit each channel, total buffer is 360*8 = 2880 bytes
    i2s_config_t i2s_config = {
        .mode = I2S_MODE_MASTER | I2S_MODE_RX,
        .sample_rate = SAMPLE_RATE,
        .bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT,
        .channel_format = I2S_CHANNEL_FMT_ALL_LEFT,
        .communication_format = I2S_COMM_FORMAT_STAND_MSB,
        .dma_buf_count = 6,
        .dma_buf_len = 60,
        .use_apll = true,
        .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1                                //Interrupt level 1
    i2s_pin_config_t pin_config = {
        .bck_io_num = I2S_BCK_IO,
        .ws_io_num = I2S_WS_IO,
        .data_out_num = I2S_DO_IO,
        .data_in_num = I2S_DI_IO                                               //Not used
    i2s_driver_install(I2S_NUM, &i2s_config, 0, NULL);
    i2s_set_pin(I2S_NUM, &pin_config);
    // i2s_set_clk(I2S_NUM, SAMPLE_RATE, I2S_BITS_PER_SAMPLE_16BIT, 2);
    size_t bytes_read;
    while (1) {
        // setup_triangle_sine_waves(test_bits);
        i2s_read(I2S_NUM, i2s_readraw_buff, 200, &bytes_read, portMAX_DELAY);
        printf("read i2s %d:",bytes_read);
        for(int i = 0;i < 200; i++)
            printf("%x ",i2s_readraw_buff[i]);
        printf("\n");
        vTaskDelay(5000/portTICK_RATE_MS);
L-KAYA
Re: ESP32的I2S同步时钟BCK最高输出时钟达不到手册标的40MHZ
Postby L-KAYA » Tue Nov 23, 2021 3:48 am
mr_jing 您好,
非常感谢您的反馈,请问能否提供一下这些,以便定位具体问题:
1. IDF版本
2. 文档关于BCK最高能到40MHz表述的具体段落
3. 使用的逻辑分析仪采样频率
从提供的代码中发现i2s_config_t中的mclk_multiple字段并未设置,默认为256,由于BCLK是由MCLK分频得到,而MCLK由APLL或PLL160M分频得到,想要获得较大的BCLK,就需要设置较小的MCLK分频系数以及BCLK分频系数,MCLK的分频系数是自适应的,没法改变,BCLK的分频系数与mclk_multiple即MCLK对于采样频率sample rate的倍数决定,关系如下:
MCLK = sample_rate * mclk_multiple
BCLK = sample_rate * channel_num * bits_per_sample
bclk_div = MCLK / BCLK
channel_format = I2S_CHANNEL_FMT_ALL_LEFT ——> channel_num = 2
bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT ——> bits_per_sample = 32
因此可以尝试将mclk_multiple取一较小值,但必须是channel_num * bits_per_sample的倍数
Image Pasted at 2021-11-23 11-01.png (29.84 KiB) Viewed 7869 times
mr_jing
Postby mr_jing » Tue Nov 23, 2021 8:57 am
mr_jing 您好,
1. IDF版本
3. 使用的逻辑分析仪采样频率
感谢您的指导,我尝试修改了mclk_multiple,最终BCLK的频率可以输出40MHZ。
BLCK时钟波形:
修改如下:
#define SAMPLE_RATE (620000)
.dma_buf_count = 6,
.dma_buf_len = 60,
.use_apll = false,
.mclk_multiple = 128,
按照理论计算BCLK = sample_rate * channel_num * bits_per_sample --> 40MHZ = sample_rate * 2 * 32 --> sample_rate = 625000,
实际测试:
sample_rate 设置为 620000,就已经输出40MHZ的BCLK,
sample_rate 设置为625000,反而输出不了40MHZ。
L-KAYA
Postby L-KAYA » Wed Nov 24, 2021 5:53 am
mr_jing 您好,
对于您提到的频率不准确的问题,是由时钟源造成的。使用较高采样频率时,PLL160M的时钟分频精度较差,而APLL时钟源能够产生一个更精确的频率,但由于驱动中APLL分频系数计算方式的局限性,目前对于高采样频率的支持不够好,我们会尽快修复该问题,感谢您的反馈!
Ps: 当使用APLL时,其最高支持128MHz,而从APLL分频得到MCLK至少为2分频,即MCLK <= 64MHz,一般MCLK到BCLK也至少是2分频,所以此时BCLK <= 32MHz
Users browsing this forum: Semrush [Bot] and 1 guest
