Unable to write pointer from xQueueRecieve
captain_morgan
Postby captain_morgan » Thu Dec 02, 2021 7:00 pm
The crux of my issue is that I am unable to increment a value on a pointer to a typedef struct that is acquired from xQueueRecieve. The setup is a very standard long running task that waits for xQueueReceive to be fed from the GPIO ISR. The entirety of the code can be found here and I will call out lines and provide snippets here to describe the flow.
Here's the problematic section. Starting here.
  // allocate lora32_cfg_t to receive config from Queue
  lora32_cfg_t *lora = malloc(sizeof(lora32_cfg_t));
  while(1) {
    // wait for event over Queue
    if(xQueueReceive(dio_event_queue, (void*)lora, portMAX_DELAY) != pdPASS) continue;
    lora32_set_frequency(lora, lora->frequency + (lora->channels[lora->channel] * bandwidths[lora->bandwidth]));
    lora->channel++;
In this snippet lora->channel does increment but the next time the interrupt is called it's back to 0. Note this is a stripped down version of the task and all pointer reads seem to work fine.
One of my suspicions is the malloc at the start but I'm unable to think of another way to handle multiple devices with a single task. Another area of concern is the path the pointer takes. The setup start around line 583. Here the lora32_cfg_t is passed to the ISR handler, which simple passes it along with xQueueSend, doing nothing else.
Line 583
gpio_isr_handler_add(lora->dio0, lora32_on_dio, (void*)lora);
Line 449
 static void IRAM_ATTR lora32_on_dio(void *arg) {
  xQueueSend(dio_event_queue, arg, (TickType_t)0);
Note: Changing this to xQueueSendFromISR does not fix the problem.
I'm pretty stumped by this one, when reading all the data seems fine and intact but writing back to the pointer clearly isn't working. Any insight would be appreciated and I'll keep updating this for clarification as I get back to hacking.
captain_morgan
Re: Unable to write pointer from xQueueRecieve
Postby captain_morgan » Thu Dec 02, 2021 9:10 pm
wowee! took a fair bit of hacking but I found my issue. It's strange this worked at all and clearly I need a better understand of passing pointers to FreeRTOS Queues. It was a two part issue, first I was initializing my Queue incorrectly.
dio_event_queue = xQueueCreate(10, sizeof(lora32_cfg_t));
should have been
dio_event_queue = xQueueCreate(10, sizeof(lora32_cfg_t *));
With that in place I changed the ISR from
to
  xQueueSend(dio_event_queue, (void*)&arg, (TickType_t)0);
It's this second part I dont' quite understand, if I'm already receiving a pointer, why do I need to also point to that? Anyhow, esp32-lora now support channel hopping!
Users browsing this forum: ChatGPT-User, PerplexityBot, PetalBot and 1 guest
