bluetooth client error message
dhs2017
Postby dhs2017 » Wed Jul 19, 2017 8:48 am
Hi all,
when i run the example gatt client, it always show this error log, anyone know how to solve this?
E (1162) BT: l2cble_start_conn_update, the last connection update command still pending.
E (1562) BT: l2cble_start_conn_update, staus = 1, line = 509
E (1742) BT: l2cble_start_conn_update, the last connection update command still pending.
also, after i connected a while , it will disconnect and show below error message.....anyone can help?
E (31382) BT: btm_sec_clr_temp_auth_service() - no dev CB
E (31382) BT: bta_gattc_conn_cback() - cif=3 connected=0 conn_id=3 reason=0x0013
E (31382) BT: bta_gattc_conn_cback() - cif=4 connected=0 conn_id=4 reason=0x0013
E (31392) BT: Device not found
E (31402) BT: bta_gattc_mark_bg_conn unable to find the bg connection mask for: 00:00:50:00:15:10
tharunjoy
Re: bluetooth client error message
Postby tharunjoy » Thu Nov 07, 2019 5:58 am
I am getting same error.
Did you resolve this?
chegewara
Postby chegewara » Fri Nov 08, 2019 8:37 pm
If you are using esp-idf v4.x or master, you can try to use this option:
CONFIG_BT_SMP_SLAVE_CON_PARAMS_UPD_ENABLE: │
│ In order to reduce the pairing time, slave actively initiates connection parameters │
│ update during pairing. │
│ Symbol: BT_SMP_SLAVE_CON_PARAMS_UPD_ENABLE [=n] │
│ Type : boolean │
│ Prompt: Slave enable connection parameters update during pairing │
│ Location: │
│ -> Component config │
│ -> Bluetooth │
│ -> Bluedroid Options │
│ -> Bluetooth Low Energy (BT_BLE_ENABLED [=y]) │
│ -> Include BLE security module(SMP) (BT_BLE_SMP_ENABLE [=y])
Also make sure you not try to send conn param update few times, because error log is suggesting you do.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 3 guests
